My car is having some serious problems...please help, thanks
Old Jan 27, 2002 | 05:37 PM
Yyz's Avatar
Yyz
Default My car is having some serious problems...please help, thanks
My car sputters (at least that is the best way I can think of how to describe it) and seems like it is not getting adequate fuel or a spark is not being fired. It is almost like it is being choked. But it only does it at low RPMs but not at idle. When I am in gear and start moving it about chokes out from about 1500-3500 rpms. I have to rev it up while driving to keep it from doing that. But if I don’t rev it just keeps sputtering, but not enough so that the car stalls, until I take it out of gear.
It started the other day and would only do it when I was in second gear, but over the next few days it started doing it every time I started and does it in about every gear, well at least up until third, b\c that is as high as I have gotten before having to cut it off. But whenever I finally get the car above 3500 RPMs it stops. I’ll start driving, it will do it, and then I get over 3500 RPMs and it stops. Then I shift gears and the RPMs drop back down into the lower RPMs and it will happen again until I get in the higher RPMs and so on…
Can anyone think of what the problem might be? My car is a 95 GSR with 100878 miles on it.
Thanks for any input
Old Jan 27, 2002 | 05:41 PM
Jmm0056's Avatar
Default Re: My car is having some serious problems...please help, thanks (Yyz)
have you checked your plugs?
Old Jan 27, 2002 | 05:46 PM
Yyz's Avatar
Yyz
Default Re: My car is having some serious problems...please help, thanks (Jmm0056)
Well I had Acura replace them at 97000 miles, and they put new plugs in then, It has had all of the necessary scheduled work that needs to be done on it. I had the 100000 Mile check up done at 97000.
Old Jan 27, 2002 | 05:59 PM
Hapa DC5's Avatar
had the same problem, probably inigition connection (coil) somewhere... any msd components?
Old Jan 27, 2002 | 06:01 PM
Jmm0056's Avatar
Default Re: My car is having some serious problems...please help, thanks (NemesisGSR)
you should check your plugs, could be a number of things, even though the plugs are fairly new one of them could have a hairline crack in it and its not firing correctly, but i am sure that if you check your plugs it'll help you figure out the problem
Old Jan 27, 2002 | 08:20 PM
Wildohiorice's Avatar
New User
could be fuel if water got in there from condensation but mileage and wear i'm leaning towards.
Old Jan 27, 2002 | 08:57 PM
Comtechgsr2000s's Avatar
New User
When was the lat time you changed your fuel filter?
Old Jan 27, 2002 | 09:15 PM
Yyz's Avatar
Yyz
Default Re: My car is having some serious problems...please help, thanks (Mugenblkgsr2000)
im not sure when the last time I changed the fuel filter, but I think they do that at the 100000 mile check up.
I dont have any aftermarket plug or wires. My wires are old, so I am thinking it might be them.
Digitalis
Jun 30, 2018 09:54 PM
rockHard
Transmission & Drivetrain
Dec 30, 2008 10:23 PM
marko-
Mar 30, 2008 06:08 PM
Beezle
Mar 31, 2005 10:45 AM
integra*RS*
May 15, 2003 11:22 AM
