Ok to run Fluidyne Radiator w/out Fans?
Old Aug 9, 2005 | 06:20 PM
db8sedan's Avatar
Default Ok to run Fluidyne Radiator w/out Fans?
Here's a question, is it safe to run just the full size fluidyne radiator without any fans? The reason why I am asking is b/c space is limited in my engine compratment and I'd like to save as much space as possible. Thank You
This is for an Integra
Old Aug 9, 2005 | 06:40 PM
hxtasy's Avatar
Default Re: Ok to run Fluidyne Radiator w/out Fans? (DB8Sedan)
you need a fan when your idling for more than 10 minutes. you def should put a fan on your priority list.
Old Aug 9, 2005 | 07:06 PM
2k.civic.si's Avatar
Default Re: Ok to run Fluidyne Radiator w/out Fans? (pennhatch)
ive seen fans that are less then an inch thick....ive also seen fans that push air instead of pull and mount on the front of the radiator....you need a fan....
Old Aug 9, 2005 | 07:19 PM
SHystrdyGSRtdy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DB8Sedan &raquo;</TD></TR><TR><TD CLASS="quote">Here's a question, is it safe to run just the full size fluidyne radiator without any fans? The reason why I am asking is b/c space is limited in my engine compratment and I'd like to save as much space as possible. Thank You
This is for an Integra</TD></TR></TABLE>
if everyone else can do it, you can do it... you need a fan (slim fan preferred)
Old Aug 9, 2005 | 11:52 PM
db8sedan's Avatar
Default Re: Ok to run Fluidyne Radiator w/out Fans? (SHystrdyGSRtdy)
thanks. I already do have a flex lite fan but I was hoping a fan isn;t needed. guess i was wrong.
Thakns again
Old Aug 10, 2005 | 05:52 AM
PM-Performance's Avatar
lol.
this post is funny.
You NEED a fan if you plan on driving the car. End of story.
VTEC_PRODUCTION
Aug 17, 2009 04:20 AM
almostboostedgsr
Jul 26, 2007 10:40 PM
Ti3d in
Oct 8, 2005 02:59 PM
fanta!
Jul 21, 2005 01:13 PM
dAng! Kris
Apr 6, 2005 07:40 PM
