HELP! obd2 vs. obd1 b18c1 block. What is the difference?
Old Aug 9, 2005 | 02:21 PM
blu3g's Avatar
Default HELP! obd2 vs. obd1 b18c1 block. What is the difference?
I'm buying a motor tonight and im wondering what is the difference between a obd1 gsr block and a obd2 gsr block. Is there even any difference? Please help let me know asap.
thanks
Old Aug 9, 2005 | 03:32 PM
Crisgo's Avatar
Default Re: HELP! obd2 vs. obd1 b18c1 block. What is the difference? (blu3g)
Only difference I know off hand is the oil pump, difference being that a obd 2 gsr oil pump has the alum. casting to support a ckp (crank position) sensor. You will need that if you run a obd 2 ecu. Other then that I dont believe there is a diff.
Old Aug 9, 2005 | 03:46 PM
blu3g's Avatar
is there a way where i can run a obd1 oil pump and eliminate the crank sensor? Or else just remove the crank sensor and still run the obd2 oil pump, since the motor will be going into a 92-95 hatch?
Old Aug 9, 2005 | 04:18 PM
LAWNMOWER's Avatar
Default Re: (blu3g)
I have a OB2 GS-R block in my 94 Si. If you put a new oil pump on just order one for a OBD1 GS-R, or you could just leave the sensor unplugged. If you do change oil pumps know that the bottom timing covers are different also. You need the timing cover for which ever oil pump you use. I didnt know this and ordered a oil pump for a OBD1 car so now I have no bottom timing cover. I couldnt find a OBD1 timing cover. Anyway hope this helps and GOOD LUCK
Old Aug 9, 2005 | 04:31 PM
blu3g's Avatar
thanks guys for your input
Turbo-GSR1287
Apr 12, 2008 08:20 AM
EM1_00Si
Jul 3, 2007 05:52 PM
standinghollow
Oct 14, 2005 12:53 PM
hackish
Oct 14, 2005 11:30 AM
Hockey27925
Mar 2, 2005 07:45 PM
