Are this cams to Big?
Old Feb 21, 2002 | 01:11 PM
Speedy Gonzalez's Avatar
Default Are this cams to Big?
Well I just got the spec.’s for Skunk2 New cams for the H22A. I'm planning on running stage II. But I'm little concern about the lift on the intake cam. Here are the spec.’s on Stage II. Intake Cam 267' duration and .505 Lift. Exhaust 274' degrees duration and .465 lift. Here are stage I spec.’s Intake- 266' duration .475 lift, Exhaust- 262' duration and .436 lift. Do you guy's think stage II cams are too big! Thanks
Old Feb 21, 2002 | 02:44 PM
3rdGteg's Avatar
Default Re: Are this cams to Big? (Speedy Gonzalez)
For what setup do you have? I believe it concerns the stiffness of your valve springs; your gonna have to run new valve springs for stage II anyway so get some that can handle the lift.
Old Feb 22, 2002 | 04:37 PM
fixhondas's Avatar
Default Re: Are this cams to Big? (3rdGteg)
those lift specs are close to ZEX's 57300 street/strip cam- you should definitely use different springs.
[Modified by fixhondas, 10:01 PM 2/22/2002]
Old Feb 22, 2002 | 05:52 PM
illusion's Avatar
Default Re: Are this cams to Big? (fixhondas)
um.. didnt you post this in the prelude forum? and didnt i answer it already?
according to this thread:
http://www.superhonda.com/forum/show...?threadid=1962
(read further than the opening post in the thread)
those specs are for the stage 3 skunk2's. the stage 2's have less agressive specs
carlossolorzano
May 18, 2012 04:38 PM
enemy no1
19
Feb 13, 2011 11:22 AM
2000si
Apr 15, 2002 11:40 AM
Speedy Gonzalez
Feb 26, 2002 04:50 PM
ghettoracer
Jan 31, 2002 06:04 PM
