Help...Alot of CEL Codes...
Whats up honda techs...i have a 98 ex manual motor in my 96 dx hatchback...im not doing too well with my engine...i have 8 codes...man where do i start...just bare with me and help me by telling me what i should do for each code...
Here are the codes:
3,6,14,22,23,41,74,91
Heres a site with codes... http://www.c-speedracing.com/faq/05.html
Here are the codes:
ok #3 is the map sensor on top of the tb. check if you connected the right wire plug on there
#41 is 02 sensor make sure it is plugged in you got obd2 so you should have 2 o2 sensors installed
#6 and 14 and 3 might be all switched so check the wires.
22 you have to run 1 wire to ecu coz your dx did not come with vtec. i wonder why 21 didnt come up coz they're in the same category
23 run another wire to ecu
