Suspension & Brakes Theory, alignment, spring rates....
Ground Control Spring rate?
Old Aug 9, 2005 | 07:38 AM
DJ_CARY's Avatar
Default Ground Control Spring rate?
How can u tell the spring rate on this?
front 150.64.66
rear 125.64.75
tnx
Old Aug 9, 2005 | 08:06 AM
Marauder's Avatar
Default Re: Ground Control Spring rate? (DJ_CARY)
The spring rate is the last two numbers. They are rated in N/mm
multiply by 5.71 to get it in lb/in
66 x 5.71 = 377 lb/in springs
75 x 5.71 = 428 lb/in springs
Old Aug 9, 2005 | 08:17 AM
DJ_CARY's Avatar
Default Re: Ground Control Spring rate? (Marauder)
thanks!
Old Aug 9, 2005 | 09:17 AM
Tyson's Avatar
you got a 5" spring???
Old Aug 9, 2005 | 03:20 PM
DJ_CARY's Avatar
Default Re: Ground Control Spring rate? (Tyson)
what do u mean 5" spring?
Old Aug 9, 2005 | 03:22 PM
vtecvoodoo's Avatar
Future Texas Boy
Community Builder
He means that the gc125.64.75 is a 5" spring, which is probably standard in the EP3 kit.
Old Aug 9, 2005 | 03:28 PM
DJ_CARY's Avatar
Default Re: Ground Control Spring rate? (vtecvoodoo)
so i can use this kit for my ep3?
how low can it go?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Marauder &raquo;</TD></TR><TR><TD CLASS="quote">The spring rate is the last two numbers. They are rated in N/mm
75 x 5.71 = 428 lb/in springs</TD></TR></TABLE>
im confused
the stock spring rate for ep3 is Stock EP3: Spring Rate: (248 Front/440 Rear)
So ur telling me it's SOFTER @ the rear? why is that?
is this worth GETTING?
IS it COMPATIBLE with KONI's?
Modified by DJ_CARY at 4:41 PM 8/9/2005
Old Aug 9, 2005 | 04:03 PM
bad-monkey's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DJ_CARY &raquo;</TD></TR><TR><TD CLASS="quote">so i can use this kit for my ep3?
how low can it go?
im confused
Modified by DJ_CARY at 4:41 PM 8/9/2005</TD></TR></TABLE>
Somehow i doubt that those are the stock EP3 spring rates...i could be wrong though, i know dick about that chassis.
They're probably worth getting, whether they're compatible with konis or not depends on whether you've got the right hardware (adapters for koni yellows) or the right koni specific GC sleeve.
Old Aug 9, 2005 | 04:07 PM
Tyson's Avatar
Default Re: Ground Control Spring rate? (bad-monkey)
wheel rates are different for each vehicle. who knows.
thats another reason why i say the simple "stiffer in the rear is better" philosophy is just a ridiculous blanket statement.
anyway, EP3 chassis uses 5" springs. interesting.
Understeer
Suspension & Brakes
May 2, 2006 08:39 PM
NA95d16z6
Suspension & Brakes
29
May 5, 2005 09:40 AM
Sam268
Aug 12, 2003 08:21 AM
96 SOHC VTEC
Mar 30, 2003 10:17 AM
Doctor CorteZ
Feb 27, 2002 06:07 PM
