What are these spring rates?
Old Mar 30, 2003 | 09:51 AM
96 SOHC VTEC's Avatar
Default What are these spring rates?
I found this on a website, but I am having trouble figuring out how to calculate spring rates. What are the spring rates for springs that are
GC 200.64.58
GC 180.64.44
How do I tell what my spring rates are?
Ground Control sells Eibach Race Springs (ERS) which are labelled by 3 different values in the following convention: length.diameter.spring rate. However, ERS will come labelled in either Metric (mm.mm.N/m) or English (inchx100.inchx100.lbs/inch) units. 180.64.61 is the same thing as 700.250.350. The conversion from Metric to English is (/.254, /.254, x5.7) "/" means "divide by", "x" means "multiply by".
Old Mar 30, 2003 | 10:11 AM
B16A1-EF9's Avatar
Default Re: What are these spring rates? (96 SOHC VTEC)
My springs say 220/50 for the fronts and 200/50 for the rears. What spring rate is that?
Old Mar 30, 2003 | 10:17 AM
Default Re: What are these spring rates? (B16B-EF9)
That is what I want to know. It gives an equation in the info I gave on how to convert it, but I don't think I am doing it right.
aznriceryder
Suspension & Brakes
Oct 26, 2007 09:37 AM
P@@RB@Y
Suspension & Brakes
Dec 26, 2005 08:38 AM
NA95d16z6
Suspension & Brakes
29
May 5, 2005 09:40 AM
Exclusiv3
Mar 25, 2004 06:55 AM
Doctor CorteZ
Feb 27, 2002 06:07 PM
