Blown compression rings on a B16A. Going to tear the head off to check.
Old Aug 9, 2005 | 04:37 AM
blaze the chemi's Avatar
Default Blown compression rings on a B16A. Going to tear the head off to check.
Hey fellas!
I have a B16A (first generation) in my 00 Si with possible compression rings blown or cracked. The compression test came back reading #1 cylinder 70 psi and the other 3 @ 170 psi. The leak down test gave a 65% loss of air which really sucks. The leak can be heard down in the crankcase area. I am planning on doing this myself with some help of friends.
I need a little advice from you all that have done this. I have the Helms and I am going through all the steps and will be getting the appropriate tools from the dealership, or a good Auto store. Upon inspection after taking the head off we will be able to see if the piston is cracked as well. I am sure the ringlands have started to go since this car is boosted. Let me know of some good pointers so this replacement can go smoothly as possible. I do plan on getting the head checked out while it is off. Thanks!
vi3t00si
Mar 27, 2006 06:30 PM
blaze the chemi
Aug 8, 2005 08:28 AM
Unlimitationz
Feb 22, 2005 03:47 PM
mick
Jun 7, 2002 07:43 AM
BoostinDC2
Feb 1, 2002 08:50 AM
