a few questions on changing oil..
Old Aug 8, 2005 | 12:21 PM
Dr Miller's Avatar
Default a few questions on changing oil..
well, i decided to start changing my own oil, and i just had a few questions. first of all, i have a 95 eg with an ls-turbo swap, so i will need an oil filter for a second-gen integra ls, right? also, what oil is most recommended for a turbo setup? thanks guys.
Old Aug 8, 2005 | 09:39 PM
Simple's Avatar
Default Re: a few questions on changing oil.. (Dr Miller)
you have a LS turbo honda.. and you dont know how to change the oil on your own engine? do yourself a favor and dont do it... take it somewhere... preferably to someone who KNOWS what they are doing...
IF YOU MUST do it yourself, use a OEM honda filter from the year of block you have... in all reality, its the same damn filter on every car besides the S2000 the 87 and lower accords, and the insights. so i dont think you have a high chance at screwing that up. better search for the recommended oil viscosity tho, try the forced induction section, or the seach button
Old Aug 8, 2005 | 09:57 PM
94_HATCH's Avatar
Default Re: a few questions on changing oil.. (Simple)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dr Miller &raquo;</TD></TR><TR><TD CLASS="quote">well, i decided to start changing my own oil, and i just had a few questions. first of all, i have a 95 eg with an ls-turbo swap, so i will need an oil filter for a second-gen integra ls, right? also, what oil is most recommended for a turbo setup? thanks guys.</TD></TR></TABLE>
You can't be serious....
Old Aug 8, 2005 | 10:01 PM
RangerDan's Avatar
Hey you gotta start somewhere...its just a bit if a strange start.
Anyways the number one newbie oil filter change screw up would have to be not checking the old oil filter to make sure the rubber gasket is not still on the block.
Old Aug 8, 2005 | 10:06 PM
1995Ex_Sedan's Avatar
1. You can't check the oil with the car running.
2. Start the car after you change the oil.
3. While you are under there, look for any signs of leaks, Check your cv boots.
4. Do not use a wrench to tighten the filter.
Old Aug 8, 2005 | 10:39 PM
mr cx hatch's Avatar
Default Re: (1995Ex_Sedan)
use a new washer when you put on the drain bolt-don't tighten it super tight cause you'll end up strippin' the bolt or the oil pan. HAND tight the new oil filter.
Dubs13
Aug 1, 2009 07:22 PM
waken
Aug 24, 2008 12:40 PM
Kingsta18
Honda S2000
21
Jul 11, 2006 04:12 PM
floatfisher
Jun 28, 2006 05:03 PM
InFaMoUs GsR
Nov 4, 2004 07:10 AM
