Best hood to lower under hood temp
Old Aug 8, 2005 | 10:51 AM
collapsedblkhrt's Avatar
Default Best hood to lower under hood temp
Hey guys. I have an EG hatch with a gsr turbo set up. My under hood temp is kind of high and i was wondering what style hood is the best at cooling your engine bay. I know some hoods are made for looks and some actually for function so which hood is the best at doing what i need? Construction material is not important and weight really isnt that big of an issue. Thanks in advance
Old Aug 8, 2005 | 11:06 AM
accordselux's Avatar
Me Gusta History
Default Re: Best hood to lower under hood temp (collapsedblkhrt)
First try lowering the underhood temp by isolating the turbo. I've seen turbo 'bag' things that keep the turbocharger insulated. You could also use header wrap on your downpipe, manifold, etc.
If you want, you can then put longer bolts with washers on your hood hinges. This will make the hood sit higher in the back, allowing more air to flow in it.
If that doesnt work then look into some carbon fiber or fiberglass hoods with scoops.
Old Aug 8, 2005 | 11:59 AM
hoffman4684's Avatar
Clicky here...
http://www.raceonusa.com/index...D=507
Old Aug 8, 2005 | 12:07 PM
Me Gusta History
Default Re: (hoffman4684)
That thing is COOL. And it is actually USEFUL!
Try the free hood mod before you go and spend 700 bucks on that though
Old Aug 8, 2005 | 12:14 PM
mike1114's Avatar
Default Re: (accordselux)
At $682 its tight but I would NEVER pay that much.
Here's a cheap alternative.
http://www.240sx.org/links/installs/hood/hood.htm
This is what I'm gonna do.
I would also suggest a turbo blanket like said and thermal coat your manifold. Heat wrap your downpipe too. I did all of these then some.
I HATE THE GHEY *** WASHER TRICK ON THE BACK OF THE HOOD
oh and by the way, this topic was covered MANY TIMES RECENTLY
Old Aug 8, 2005 | 01:02 PM
VWVORTEX's Avatar
Default Re: (mike1114)
thats a pretty good idear for the hood, a bit ricey but it would help a minor bit
alacard
23
Jan 4, 2007 01:39 PM
shomershavis
Sep 12, 2004 10:01 AM
scooter
Jul 16, 2003 03:46 PM
GraphiteAccord
May 5, 2003 12:00 PM
RATEDR
Jul 4, 2002 12:25 AM
