Cant break 300 whp......WTF!?!?
Old Aug 8, 2005 | 09:21 AM
allanonjj's Avatar
Default Cant break 300 whp......WTF!?!?
Alright, Im not as well veersed in turbo-lingo 101 but I'll do my best. ls vtec, 9/1 comp cp's, eagle rods, skunk 2 intake, 550 injctors, walbro 290 pump, 2.5 inch piping, greddy cooler, dom-data tuning,....and finally the snail,....its a t3-B I THINK. Im not sore about the other #'s. My question is this. Could that turbo be whats keeping me under 300 whp??? I hate to ask bc I dont know the turbine,...um inlet,.... outlet,..... flux capacitation blah blah. All I know is like I said,.... T3-B came with the drag kit. cost right @ 3000 w/injectors.
Anyone?
Old Aug 8, 2005 | 09:25 AM
liam821's Avatar
25 Year Member
Default Re: Cant break 300 whp......WTF!?!? (allanonjj)
Most of the drag turbo are a t3/t04b 57trim - it will support 400hp. How much boost are you running? What fuel mangement?
liam
Old Aug 8, 2005 | 09:26 AM
Redline130's Avatar
What's your exhaust set-up?
Old Aug 8, 2005 | 09:36 AM
Dunc's Avatar
BCICAN
Default Re: Cant break 300 whp......WTF!?!? (Redline130)
well change to 3" exhaust...that will help gain a little. If it is a true T3 and not a T3/T4, then that may explain why you can't break 300.
Old Aug 8, 2005 | 09:37 AM
allanonjj's Avatar
Im not sure what management software my tuner is using. 14 lbs of boost @ 293 whp. 3" downpipe, 2.5" the rest of the way out
Old Aug 8, 2005 | 09:43 AM
elpiar's Avatar
What's your compressor wheel trim on the t3?
Old Aug 8, 2005 | 10:13 AM
boostincoupe's Avatar
From: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allanonjj &raquo;</TD></TR><TR><TD CLASS="quote">Im not sure what management software my tuner is using. 14 lbs of boost @ 293 whp. 3" downpipe, 2.5" the rest of the way out</TD></TR></TABLE>
Ummm, that would help us?
Old Aug 8, 2005 | 10:17 AM
EARLdaSQUIRREL's Avatar
official honda whore
could be your tuner is just tryin to run it safe and he has the timing set back a lil bit, also whats your compression #'s
brian
Old Aug 8, 2005 | 10:25 AM
wantboost's Avatar
Who is Mr Robot?
Default Re: Cant break 300 whp......WTF!?!? (coptzer)
get used to it. my buddy had a fully built b16 block with a t3/t04b at 14psi it was 290 at hte wheels and at 19-20 it was like 300. get a t3/t04e and watch the power magically jump. the "b" wheel is good for high flow/low pressure ratio applications, which hondas clearly arent
Old Aug 8, 2005 | 11:59 AM
Benjithx's Avatar
Default Re: Cant break 300 whp......WTF!?!? (wantboost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wantboost &raquo;</TD></TR><TR><TD CLASS="quote">get used to it. my buddy had a fully built b16 block with a t3/t04b at 14psi it was 290 at hte wheels and at 19-20 it was like 300. get a t3/t04e and watch the power magically jump. the "b" wheel is good for high flow/low pressure ratio applications, which hondas clearly arent</TD></TR></TABLE>
hmm...who was that? ...punk
Old Aug 8, 2005 | 12:06 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: Cant break 300 whp......WTF!?!? (Benjithx)
well that was you, until you sold out and went german. biotch
oh well, at least i sold a motor, lol
Old Aug 8, 2005 | 12:12 PM
BoOsTeD C1's Avatar
I agree the t3/t04e is much better then B model.Wish i could have made it to 300hp mark too but Iam only 266whp@6psi on the t3/t04e...I got fuel issues so i cant turn up the boost yet.
Old Aug 8, 2005 | 01:04 PM
allanonjj's Avatar
Default Re: Cant break 300 whp......WTF!?!? (VTEC_pWrD_CiViC)
That sounds right. My friend highrevvs99 has the same setup as me but with that turbo and he makes 408whp. he does however have typer cams and an equall length mani as well as 3" exhaust.... ok, he has some more parts but he gets to 408 @ 14 lbs of boost opposed to my 293 @ 14 lbs. So that makes since to me. How much could I get for my turbo? Ive only had it on for about 3 months and a month of which I wasnt even driving the car. Whats it worth? How much is a good price for a t3/t04e?
Old Aug 8, 2005 | 01:09 PM
allanonjj's Avatar
ok,....I think I need to re-word my question. Given what you already know about my setup, which turbo should I get in order to reach 400whp?? Am I going to need bigger injectors??? Keep in mind this car is a D.D. and its not sleeved. Am I stupid for attempting this with a stock block(unsleeved)? I mean, Ive heard of several 500hp+ D.D.'s on here but they all had sleeved blocks.
Old Aug 8, 2005 | 02:24 PM
allanonjj's Avatar
Ive had several requests for the dyno gragh so here it is. Oh and Im using chrome.
mrbsponge
Sep 16, 2004 10:11 AM
EH2LS
Sep 6, 2003 11:04 PM
turbogsr13z
Jul 25, 2002 01:01 PM
9KRacer
Jan 30, 2002 04:58 AM
