Estimate on Power
Old Jan 28, 2002 | 11:25 AM
9KRacer's Avatar
New User
Default Estimate on Power
I am having a B18C1 sleeved with rods. pistons all the precautions. I am planning on running 20 lbs of boost. I am trying to get a rough estimate of what kind of power this will produce? Any ideas, anyone running that nuch boost?
[Modified by 9KRacer, 4:01 PM 1/28/2002]
Old Jan 28, 2002 | 11:36 AM
BoM's Avatar
BoM
Default Re: Estimate on Power (9KRacer)
low 15's, but if u had mentioned a turbo size maybe it would be faster!
typical t3/t4 turbo would make over 400whp
Old Jan 28, 2002 | 11:59 AM
9KRacer's Avatar
New User
Default Re: Estimate on Power (BoM)
Sorry, I am going with Drag 3..
Old Jan 28, 2002 | 12:03 PM
b18bturbo's Avatar
i think at 20 psi you can hit over 400hp easily. I know with my built motor and 22 psi i hit little over 525hp.
Old Jan 28, 2002 | 12:09 PM
rtype11's Avatar
Default Re: Estimate on Power (b18bturbo)
are you sure the kit supplied T3/4 can support the airflow necessary for 525hp?
that would have to be the T3o4E tuned to the ragged edge - n'es pas?becomes unstab
I thought the standard kit t3/4 can manage 300max untill bosst becomes unstable.
Old Jan 28, 2002 | 12:15 PM
b18bturbo's Avatar
Default Re: Estimate on Power (rtype11)
no i am tlaking using his t3/4 setup that drag sends with .63 ar you should be able ot hit 400hp.
My 525 was done witha differnt turbo setup To4s
Old Jan 28, 2002 | 12:16 PM
DIRep972's Avatar
Smarter than you
b18bturbo is not using a drag3 T3/T04e
damn u beat me to it
[Modified by DIRep972, 9:16 PM 1/28/2002]
Old Jan 28, 2002 | 12:28 PM
BoM's Avatar
BoM
Default Re: Estimate on Power (DIRep972)
with the kit you will need to upgrade some parts
the wastegate, the downpipe, 3inch exhaust, fuel management
all help with the high boost....
Old Jan 29, 2002 | 04:21 AM
9KRacer's Avatar
New User
Thanks. WOuld it be better if I just pieced a kit together? I know sometimes, you can get better parts is you get them separately.
Old Jan 29, 2002 | 06:56 AM
b18bturbo's Avatar
very true its good to piece together a kit but if you are on budget i would jsut a drag 3 and build from there.
Old Jan 29, 2002 | 09:47 AM
Adi Radoncic's Avatar
On Fire!
As fahr as I know a T3/T4 supports 450hp at 25 and that is the .54 .63 T04E that comes in the drag lll kits...
Adi
Old Jan 30, 2002 | 04:58 AM
9KRacer's Avatar
New User
Default Re: Estimate on Power (newgsr)
I am still learning all the codes for the turbo. I know the t3/t4 housing is the most popular. Its the .63 .43 number I am still learning about. So i guess the Drag 3 is a good starting point. COuld I stil run off the stock ECU?
1lowek2007
Dec 5, 2012 06:53 PM
Cole89ef
Aug 6, 2009 07:03 AM
SiKid86
Sep 14, 2006 08:57 AM
mrbsponge
Sep 16, 2004 10:11 AM
10secsi
Jul 28, 2002 03:34 AM
