Swapping Integra hatches
Has anyone ever done this? I recently swapped out my hatch in favor of a GSR one and it doesn't shut properly and neither is it aligned right. I tried adjusting it at the bolt points behind the roof liner, but to no avail. I also tried adjusting the latch.
Those who have done this, do you have any advice to adjust it properly?
well to start off theres 4 bolts under ur headliner just pull the trim off and stck a socket under the liner. there def is not to much play with these bolts they can be adjusted slighty what you would have to do is loosen all 4 bolts and alig the hatch properly and then have someone inside te car tighten te bolts. as for the lock there is some play but i woud just keep it dead center wen u start. good luck.
good luck
