Swapping Integra hatches
Old Aug 8, 2005 | 06:49 AM
B18Redline's Avatar
Default Swapping Integra hatches
Has anyone ever done this? I recently swapped out my hatch in favor of a GSR one and it doesn't shut properly and neither is it aligned right. I tried adjusting it at the bolt points behind the roof liner, but to no avail. I also tried adjusting the latch.
Those who have done this, do you have any advice to adjust it properly?
Old Aug 8, 2005 | 08:43 AM
gsr dood's Avatar
Default Re: Swapping Integra hatches (B18Redline)
well to start off theres 4 bolts under ur headliner just pull the trim off and stck a socket under the liner. there def is not to much play with these bolts they can be adjusted slighty what you would have to do is loosen all 4 bolts and alig the hatch properly and then have someone inside te car tighten te bolts. as for the lock there is some play but i woud just keep it dead center wen u start. good luck.
Old Aug 8, 2005 | 08:44 AM
gsr dood's Avatar
Default Re: Swapping Integra hatches (gsr dood)
also u can play with the rubber bushings by unscrewing/screwing them in to get the hach to sit right. good luck
Old Aug 9, 2005 | 09:03 AM
B18Redline's Avatar
thanks man, thats what I have been doing, but for some reason it isn't opening or closing properly
JJGL-EF90
Oct 8, 2010 01:27 PM
Timberland237
Suspension & Brakes
Nov 9, 2006 11:29 AM
oMek
May 6, 2004 01:06 PM
Sonny
Apr 8, 2002 01:20 PM
hydroflip
Jan 19, 2002 11:31 PM
