Questions for the guys with H22 turbos?
Old Aug 6, 2005 | 02:10 PM
Nandezuk's Avatar
Default Questions for the guys with H22 turbos?
I am currently in the process of building a h22 turbo and have just had the block resleved and bought some je pistons and eagle rods.
I would like to know what head work you guys have done? Valve size, porting etc...
What size injectors you are running?
What type of ignition system you have?
What size turbo?
I am going for about 400bhp
Anything else that you can mention will be appreciated.
Old Aug 6, 2005 | 02:22 PM
11seclude's Avatar
Default Re: Questions for the guys with H22 turbos? (Nandezuk)
i run eagle rods,aebs sleeves and je 9:1 pistons stock head with cam gears.
turbo is a precision sc63 s cover with p trim. nology ignition ,880cc precision injectors here is my dyno at 10 psi
Old Aug 6, 2005 | 07:59 PM
Pikachu's Avatar
Actually I plan to run 15psi with my H22 Civic. I am currently running 9:1 CP pistons, Pauter Rods, stock head. Turbo is a GT35R .82ar, MSD SCI-L, 1000cc injectors. I don't have numbers yet cuz my AEM EMS just took a **** which is rare. I should be able to get numbers up within the week.
Old Aug 7, 2005 | 01:29 PM
Nandezuk's Avatar
Thanks for the replys guys.
I take it the standard head is very good. Do you have any probs with cooling?
Most impressed with that power curve.
How is you drive train coping?
I have a set of the driveshaft shop outer axles but notthe centre one. Have you kept this and the standard gearbox or toughend it up?
Old Aug 7, 2005 | 02:46 PM
john d
Guest
Posts: n/a
Default Re: (Nandezuk)
im using a t25
Old Aug 8, 2005 | 12:12 PM
freaker's Avatar
Default Re: Questions for the guys with H22 turbos? (11seclude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 11seclude &raquo;</TD></TR><TR><TD CLASS="quote">i run eagle rods,aebs sleeves and je 9:1 pistons stock head with cam gears.
WOW!! 10psi only!! Holy hell that thing would make a nun swear at 20psi!
Old Aug 8, 2005 | 12:49 PM
Nandezuk's Avatar
Default Re: (john d)
T25???
Old Aug 8, 2005 | 12:53 PM
wantboost's Avatar
Who is Mr Robot?
huh? tha dyno graph was of a precision sc63
98ej1h22
Feb 5, 2014 02:02 PM
nick6444
Mar 2, 2009 03:02 PM
mozzandherb
Jun 8, 2006 05:40 PM
djbutler007
Jun 6, 2006 10:40 PM
djnikko
Jun 21, 2005 04:43 PM
