del sol si d16z6 map wire color
im installing my vafc in my 93 del sol si 5spd, and im looking at the helms and off the post above in the forum. acording to those the map should be d17 corect? and should be green/blue(helms). or white blue (ecu post)
when i look at my wires they go like this
d15 empty
d17 empty
d18 white
d19 yellow white
d20 yellow green
d21 green white
d22 green blue
wich one is the map signal. some help would be appreciated
d15 empty
d17 empty
d18 white
d19 yellow white
d20 yellow green
d21 green white
d22 green blue
oh all so i dont have a wire solderer at the present time will the vafc still work without solder or should i wait till i can get solder gun
yeah i was getting confused because of the wiring code out of the helms not being right. ... it was upside down but thanks for the diagram it helped
