Full Race B-series GT Stage I, High Boost (plots & comparisons)
Old Aug 5, 2005 | 12:22 PM
B18CXr's Avatar
Default Full Race B-series GT Stage I, High Boost (plots & comparisons)
refer to below post for past history on this project:
https://honda-tech.com/zerothread?id=1315396
Full Race Stage I GT (non-AC)
GT28RS (Disco) with T3 hot housing
B18C1
81.5mm
Stock sleeves and crank
Stock cams and gears
Stock TB
750cc
AEM EMS
Eagle rods
9:1 Mahle pistons
Toda valve springs
ATS Carbon Clutch
USDM P73 tranny
P73 head with very, very mild port job
Victory X intake manifold
NOT DYNOJET NUMBERS!
Low boost = 10.5ish psi
High boost = 15ish psi
Note on the log viewer the duty cycle of the boost solenoid begins to creep up after 6500 to try to keep boost pressure maintained due to the small turbo, thus boost at rev limit is only 12ish. (I.E. bigger snail needed if higher than 12 pounds is desired for this application)
same data as above just shown in deltas format
Nice mid-range gains
Note: as the turbo runs out of air, the duty cycle increases on the wastegate
Enjoy
Old Aug 5, 2005 | 05:28 PM
mildly.interesting's Avatar
excellent work Yack!
I gotta bring the little green one to see you now that I've got a new tranny and a few other little pieces.
I'll be in touch!
Old Aug 5, 2005 | 09:49 PM
HRTuning's Avatar
Default Re: (mildly.interesting)
He does it yet again! You have way too much fun over there.
Old Aug 8, 2005 | 05:43 AM
B18CXr's Avatar
Default Re: Full Race B-series GT Stage I, High Boost (B18CXr)
Was hoping for a little more air flow outta the Disco, but O well.
The car was built for road course action so big boost is not the goal anyways.
Old Aug 8, 2005 | 05:52 AM
yellowturbo's Avatar
if the car was build for road racing this is pretty cool... you will have plenty of power response BUT I was expecting more than 292whp from a GT28RS at 15psi on a B18C ??
Old Aug 8, 2005 | 06:02 AM
B18CXr's Avatar
A) was not "15" psi, was 11.5ish at rev limit
b) NOT A DYNOJET
Old Aug 8, 2005 | 06:26 AM
RacerXI's Avatar
Default Re: (B18CXr)
What was the a/r on that turbo btw? Thanks for all the dyno plots posted also.
Old Aug 8, 2005 | 07:17 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18CXr &raquo;</TD></TR><TR><TD CLASS="quote"> BUT I was expecting more than 292whp from a GT28RS at 15psi on a B18C ??
b) NOT A DYNOJET</TD></TR></TABLE>
ahhh ok sorry for my mistake... now it make sense... at 15psi it will break the 300whp mark with no problem
This car must be a lot of fun to drive on a track !
Old Aug 8, 2005 | 11:39 AM
B18CXr's Avatar
Default Re: (RacerXI)
.63
Old Aug 8, 2005 | 12:02 PM
RacerXI's Avatar
Do you think the .82 a/r would have helped the power output on top end past 12psi, which you stated above?
Old Aug 8, 2005 | 06:39 PM
mrlegoman's Avatar
Those pics would be cooler if the engine would have been on the "Full-Race" engine stand........
Old Aug 8, 2005 | 07:14 PM
mrlegoman's Avatar
Note on the log viewer the duty cycle of the boost solenoid begins to creep up after 6500 to try to keep boost pressure maintained due to the small turbo, thus boost at rev limit is only 12ish. (I.E. bigger snail needed if higher than 12 pounds is desired for this application)</TD></TR></TABLE>
So if high boost is only 12psi what is the point of having a high/low boost switch?
Also, I thought this turbo was 'happy' in the 16-18 psi range according to the compressor map. I know the map we looked at was based off a different turbine, but would it make that much of a difference?
Umm, I guess obviously it does. I'm tired and going to bed.
Going to bed happy btw. This is some good chit!
Old Aug 8, 2005 | 07:54 PM
JDogg's Avatar
Default Re: Full Race B-series GT Stage I, High Boost (mrlegoman)
the turbine is too small on that turbo..chokes it pretty good on top.
3071r is much better choice for a honda that wants to make power and keep the power up top, only spools about 5-600 rpms later
Old Aug 8, 2005 | 09:04 PM
a1320addict's Avatar
Default Re: Full Race B-series GT Stage I, High Boost (JDogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18CXr &raquo;</TD></TR><TR><TD CLASS="quote">refer to below post for past history on this project:
and then...
[QUOTE=B18CXr]What was the a/r on that turbo btw?
.63</TD></TR></TABLE>
the full-race stage 1 gt setup comes with a gt28rs with a .82 a/r turbine housing.
so..im confused
Old Aug 9, 2005 | 06:24 AM
B18CXr's Avatar
As stated above:
I didn't want power "up top", massive mid-range thru the apexi towards the track out marker is what this car was made for, NOT dragwarzYOmang.
Yes, sure would have
Old Aug 9, 2005 | 11:54 AM
JDogg's Avatar
jack.. going from teh 28rs to the 3071r we actually picked alot of tq in the midrange and transient responce was actually about the same, granted it all happened about 400ish rpms later.. went from 290tq to 315tq and 374hp to 405hp and held it from full boost (20psi at 4600 with the 28rs, 20psi at 4900 with the 3071r) all the way out to 9000 rpm redline, where the 28rs falls off before 8000 rpms. this car was built for road race and auto x as well.
Old Aug 4, 2008 | 07:04 PM
B18CXr's Avatar
Up because the motor is still running
see link:
https://honda-tech.com/zerothread/2358863
P.S.
JDogg is an assclown and a moo moo
Old Aug 4, 2008 | 07:27 PM
sp00led's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18CXr &raquo;</TD></TR><TR><TD CLASS="quote">P.S. JDogg is an assclown and a moo moo</TD></TR></TABLE>
Old Aug 5, 2008 | 03:49 AM
140sx's Avatar
lol wow
Old Aug 5, 2008 | 08:33 AM
JDogg's Avatar
P.S.
aww, i love you too jack
_HANS
Mar 30, 2008 10:42 PM
RobbieG35
Jul 4, 2006 04:42 AM
B18CXr
Oct 18, 2005 06:16 AM
B18CXr
Sep 29, 2005 02:36 PM
xtremeness101
Apr 16, 2005 09:30 AM
