OBD2 P72 ECU
nope, hondata only works with obd1 unfortunately. the OBD1 P72 is a good (probably the best) ecu to run with hondata on the h22 or h23 vtec because it has the capability to control the secondary butterfly valves on the h22 intake manifold. if you plan on removing the valves anyway, just go with the P28 ecu.
you can control the butterflies with nitrous control on the s200.
though, apparently no one knows how to exactly do this.
just a matter of routing the 12v signal from the hondata to control the IM butterflies.
otakueric
10
May 22, 2004 06:07 PM
