TWIN TURBO B18C ???
Anybody built a twin turbo 4cyl. If so any useful info on this would be greatly appreicated. I know it would be easier to just use one big turbo, but i have two T25's
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by all go teg »</TD></TR><TR><TD CLASS="quote">its probably going to be easier to go with one, it would be way to hard even fit 2 turbos and all the piping under the hood of a honda. </TD></TR></TABLE>
its been done a few times on homemade turbo. check that website for more info
i just check it out, my mistake
but still i thought you usually sequencedthe turbos to to get a small turbo to spool up a bigger turbo. or can you use 2 at the same time?
It's not that it can't be done, it's that you'll end up spending 3 times as much money and will most likely slit your wrists out of frustration because there isn't enough room to fit everything in the engine bay.
not to mention engine management, the varying levels of boost and never being able to keep them consistent, among other problems. hell even the TT supra guys convert to 1 turbo after they see so much power. only reason for doing this is the wow effect...
