Sizing my turbo for GSR: t3 super 60 or t3/t04e .46 trim?
Old Aug 4, 2005 | 10:13 PM
elpiar's Avatar
Default Sizing my turbo for GSR: t3 super 60 or t3/t04e .46 trim?
Any opinion? Been researching the compressor map, but the compressor map for t3 super 60 does not have label on their efficiency curves. This is on B18C1 stock.
What are their spool time? efficient rpm ranges?
Old Aug 4, 2005 | 10:18 PM
beerbongskickass's Avatar
Default Re: Sizing my turbo for GSR: t3 super 60 or t3/t04e .46 trim? (elpiar)
t3 is way too small...
Old Aug 4, 2005 | 10:25 PM
SiKid86's Avatar
Default Re: Sizing my turbo for GSR: t3 super 60 or t3/t04e .46 trim? (beerbongskickass)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beerbongskickass &raquo;</TD></TR><TR><TD CLASS="quote">t3 is way too small...</TD></TR></TABLE>
Old Aug 5, 2005 | 12:06 AM
the.hamburglar's Avatar
Default Re: Sizing my turbo for GSR: t3 super 60 or t3/t04e .46 trim? (SiKid86)
i have a t3 super 60 on my b16 and its perfect. for a 1.8L gsr i might go with like a t3/t04e 57 trim or this:
http://blaastperformance.com/i...e4860
Old Aug 5, 2005 | 05:05 AM
RACINTWEEK's Avatar
what the hell are you doing!!!!!!!!!
come back to where you belong
Old Aug 5, 2005 | 06:58 AM
elpiar's Avatar
Default Re: Sizing my turbo for GSR: t3 super 60 or t3/t04e .46 trim? (hamburgler)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hamburgler &raquo;</TD></TR><TR><TD CLASS="quote"> i have a t3 super 60 on my b16 and its perfect. for a 1.8L gsr i might go with like a t3/t04e 57 trim or this:
http://blaastperformance.com/i...e4860</TD></TR></TABLE>
Should I choose 0.48 OR 0.63 A/R for the turbine housing on t3/t04e ?
I suppose 0.48 has less lag?
Old Aug 5, 2005 | 07:14 AM
turbochargeb18c's Avatar
BANNED
i would go w/ the .63 ar...the .48 is less lag but less top end pull then the .63 ar...its all depend on what you want...the .63 ar is not to bad of a lag
Old Aug 5, 2005 | 07:38 AM
elpiar's Avatar
Default Re: Sizing my turbo for GSR: t3 super 60 or t3/t04e .46 trim? (turbochargeb18c)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbochargeb18c &raquo;</TD></TR><TR><TD CLASS="quote">i would go w/ the .63 ar...the .48 is less lag but less top end pull then the .63 ar...its all depend on what you want...the .63 ar is not to bad of a lag</TD></TR></TABLE>
Do you currently use .63 ar? when do you reach full boost for, say 7 psi?
Old Aug 5, 2005 | 07:41 AM
id go with a .48. everyone has different opinions. i have a friend with a .63 in his gsr and its so big you dont even fill the kick of being pulled back into the seat because his starts spooling at like 5500 and reaches full boost at 6500. having a larger turbo isnt always everything. you might have huge power from 6000-8200 but while you wait for it to come one other cars are already infront of you. id go with a t3/t4 .48/.60 with a 57 trim. but thats just me. youll have to read what others think
Old Aug 5, 2005 | 07:58 AM
BANNED
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by elpiar &raquo;</TD></TR><TR><TD CLASS="quote">
i use to have the sc61....and i get full 18lb boost @ 5k rpm and it'll pull all the way to 8600 rpm...my boost gauge read 7lb @ 3800 rpm...the .48 ar is only good if you want fast mid-range pull but the .63 will give you mid to top end pull....on my sc61 it pull hard as ****....
Old Aug 5, 2005 | 08:06 AM
elpiar's Avatar
This is the calculation I did with T3 60 (not super 60) trim
So t3 is not too small as long as it's not 40 trim.
Any comments?
Old Aug 5, 2005 | 08:53 AM
elpiar's Avatar
Does turbo lag only depend on turbine AR or also on the turbine wheel trim
Old Aug 5, 2005 | 12:14 PM
elpiar's Avatar
up
Old Aug 6, 2005 | 05:34 PM
elpiar's Avatar
up again
Old Aug 8, 2005 | 09:26 PM
SiKid86's Avatar
Lag just isn't with the turbo.. The size of your exhaust has a play, the compression of the motor has a play. and I think its the wheel that effects the lag.
Old Sep 30, 2005 | 01:59 PM
mraudio13's Avatar
I have a stock GSR with a super 60 and I love it. Full boost at 3800 RPM's! I boost 10 lbs all day on stock internals and am putting down 240 to the wheels. It all depens on how much you want to build up the stock block, but for a stock GSR I like the Super 60. My 2 cents...Matt
Old Sep 30, 2005 | 02:34 PM
JDM_EH2's Avatar
Default Re: Sizing my turbo for GSR: t3 super 60 or t3/t04e .46 trim? (mraudio13)
Depends on your power goals. With a FR mani/3" DP and exhaust my friends GSR spools a t3/to43 60 trim .63ar at 4700k...pulls nicely to redline. i suggest going with a 57 trim or the 60 trim i just mentioned...both in a .63 a/r. the only time ull feel the lag is from a stop...besides we have fwd cars...lag is good
Old Sep 30, 2005 | 02:41 PM
project dc2's Avatar
Default Re: Sizing my turbo for GSR: t3 super 60 or t3/t04e .46 trim? (JDM_EH2)
my customers car runs a T3 super 60 with 48 turbine housing.
7 psi it makes 230-240 WHP with a conservative tune on a bone stock GSR with stock GSR exhuast and 440CC injectors. runs a 13.5 on streeet tires daily driven no problem. its really about what you want for your car. for him its just a quick daily driver with fast spool. personally i had this turbo on my b20 and made 262 whp 254 torque and that thing was a monster !
Old Oct 1, 2005 | 10:34 AM
yee SERIOUS's Avatar
there's a pretty noticable difference between the .48 and the .63. my .48a/r t3/to4e just blew, so i got a new .63a/r with a .57trim. and it just hulls. i get full boost a little bit later, but the butt dyno says the .63 wins.
my cousin was telling me to run a t3 for motor efficency and lasting. but maybe he just wants me slower. lol
go with a .63 so you wont need to upgrade in a turbo later.
cleanej2
Mar 8, 2007 05:06 AM
LU
Feb 22, 2007 10:45 PM
Mugencrxsir1
May 17, 2006 02:56 PM
B16Drag
May 16, 2005 09:46 PM
redboost10
Oct 24, 2003 09:03 AM
