CEL codes help!
Im throwing the following codes : 1 O2A - Oxygen sensor #1, 14 IAC (EACV) - idle air control valve, 21 VTEC spool solenoid valve, 43 Fuel supply system... help me with any kind of info how to fix this please everyone
that's a real cluster-****-a-mess you got there. sounds like you may need to replace those parts. always need specifics upfront... what exactly do you need help with? replacing or identifying or both? what year civic? how (or if) was it running before??
I'd think you may have a bigger problem that cause those codes. u might want to take the car in for a shop diagnostic. It might be your wiring. It's it's unusual for a civic to throw all the codes at the same time but anything's possible. placing parts per corresponding code is tedious. but it runs fine you say. have you reset the 'puter? need a new ecu maybe?
What kind of computer are you running? The shop that I got my swap from gave me a P72 to begin with and I was throwing a number of codes. When I told them I wanted the P30, I swapped it in and stopped throwing codes.
-Shane
-Shane
mortificationrock
11
Jan 17, 2008 02:08 PM
