Does anyone else's GC's look like THIS??!!!
I installed my GC's over KYB AGX's. I know the instructions say to grind down a bit of the front spring perch in order for the GC sleeves to fit evenly and I did that no problem. I was adjusting the height of my car a week after I installed them and I noticed my sleeves were deformed near the bottom. They were stretched outward around the spring perch and there are stress marks on the sleeve as well.
Do anyone else's GC Sleeves look like this? Over KYB AGX's?
Should I be concerned???
my sleeves never did that mounted on my tokico's. i dont remember any "grinding down" instructions either. but i can see why that happened on yours. the way i see it, i wouldnt be worried until there were any vertical cracks. then id just send it in to ground control under warranty.
that sleeve looks like it is for a koni yellow.. which uses a diff perch on the shock body that locks that sleeve from touching the bottom mounting point for the shock.. thats just my guess, someone correct me if i am worng..
Thanks guys. I checked with Ground Control and yes I did install the rear sleeves on the front shocks
......damn. I installed whatever sleeves were with the front springs when they came. I guess they were mixed around when packaged. Hopefully they'll last until I can get some new rear sleeves and swap'em.
Definitly thanks for the heads up on them being the rear sleeves. SAVED BY HT'ers!!!!
......damn. I installed whatever sleeves were with the front springs when they came. I guess they were mixed around when packaged. Hopefully they'll last until I can get some new rear sleeves and swap'em. Definitly thanks for the heads up on them being the rear sleeves. SAVED BY HT'ers!!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SlowReaction »</TD></TR><TR><TD CLASS="quote">I dont have GC myself but isnt that the sleeve that suppost to be install in the rear?</TD></TR></TABLE>
good call.
good call.
importdude2000
Suspension & Brakes
17
Oct 19, 2006 09:07 PM
spd18
Mar 13, 2003 06:56 PM
Tyson
Jan 25, 2003 06:39 PM
thinkbrianthink bu
Jul 22, 2002 08:08 AM
