Car overheats with a/c running
Old Aug 4, 2005 | 11:52 AM
vtec.dc2's Avatar
Default Car overheats with a/c running
I know turbo hondas run more heat, maybe somebody else had this and knows how to fix it..
Already replaced thermostat and radiator cap. condensor fan blades are somewhat melted but still spin air, both fans are still coming on, no coolant loss. only happens in hot weather (90 degress and up), gauge will start to climb towards middle, i turn the a/c off, and rightaway it goes back to normal. 91k on stock radiator, waterpump ~20k miles and coolant is somewhat new as i had to replace thermostat.
Old Aug 4, 2005 | 12:43 PM
shiftgear8000's Avatar
Default Re: Car overheats with a/c running (vtec.dc2)
I just had the same issue......turns out my radiator was shot, might wanna check out the condition of yours.
Old Aug 4, 2005 | 12:49 PM
tilt's Avatar
You might have to upgrade your radiator. My upper temps dropped considerably when I did.
Old Aug 5, 2005 | 07:22 AM
vtec.dc2's Avatar
Default Re: Car overheats with a/c running (shiftgear8000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shiftgear8000 &raquo;</TD></TR><TR><TD CLASS="quote">I just had the same issue......turns out my radiator was shot, might wanna check out the condition of yours.</TD></TR></TABLE>
what shoud i look for when i check the radiator? it looks fine on the outside
Old Aug 5, 2005 | 09:25 AM
porsche997dc2's Avatar
what kind of fan is your primary fan(stock or slimfan)?
Old Aug 5, 2005 | 10:21 AM
vtec.dc2's Avatar
Default Re: Car overheats with a/c running (porsche997dc2)
basically, its stock itr radiator, the radiator fan has been changed to slim fan and condenser fan is stock but the blades are melted
Old Aug 5, 2005 | 11:08 AM
A couple months ago, I did a comparison between oem fan, Proform slimfan, and Mr. Gasket slimfan. I did all the tests with ac on, no condensor fan, hwy. driving, street driving, and in a 90+ degree weather. All the fans did very good on hwy. driving. On street driving, the Proform slimfan did terrible. My temperature gauge needle started to climb. In my conclusion, some slimfans did better than the other. IMO, the efficiency of the radiator fan(primary fan) is very important with ac running.
Old Aug 6, 2005 | 04:52 AM
vtec.dc2's Avatar
i think you right about it, and all of aspects matter, i tried to disconnet the a/c condensor fan thininking possibly melted wiring might have caused this problem, but it ended up overheating even faster. so i'll try to repair the condensor fan blades and see if that going to help any
pyrojeff
Oct 21, 2019 09:50 AM
delsolnewkid
14
Feb 6, 2009 11:36 AM
cilvia
Jul 4, 2008 10:21 AM
MarkZeroNine
Dec 1, 2003 07:48 PM
92SiHatchie
31
Jul 26, 2003 10:54 AM
