Bitch pin removal...
Old Aug 4, 2005 | 11:09 AM
transpar_nt's Avatar
Default Bitch pin removal...
Anyone who's done a swap will know what I'm talking about. It's the pin that holds the 5spd linkage to the tranny. Surprise surprise, its being a bitch to get out. I know there are a lot of thread on this already, but there's one thing that confuses me. Everyone reccommends taking an 8mm punch or an AC bolt and just beating the shyte out of it with a bfh, but how? Once I put a punch in the hole, there is less than an inch between the end of it and the exhaust. I tried angling the punch a bit, but then I'm just pounding it into the side and not really hitting the pin. Any suggestions? I'm trying not to resort to pulling the linkage out with the engine cuz I cant really squeeze that far under the car. (It's on two jack stands on the lowest setting behind the front wheels. I know i know, but my shitty jack can't lift the car any higher.) Please help
Another thing. Some people mention hitting it out from the top through the engine bay... WTF? Correct me if i'm wrong, but i thought the pin was horizontal? If anyone has pictures that would sure help. Man i feel like a loser...
Old Aug 4, 2005 | 11:13 AM
HondaFanatic708's Avatar
From: San Diego, I miss Chicago, but love SD, CA, US of fuckin A
Default Re: Bitch pin removal... (transpar_nt)
No the pin is verticle like so | not horizontal like so --. If you look at it from the bottom there is sort of a bevel going in to the pin. You will need to get this 8mm punch. Sometimes going from the top is easier but there isn't too much room up there. Kinda angle the punch from the bottom into those bevels. It should start to move up. You really just have to wail on it until it breaks free. There really aren't any secrets I have heard of over the years..
Old Aug 4, 2005 | 11:15 AM
Default Re: Bitch pin removal... (HondaFanatic708)
approximately how long is the pin? I've also heard that there is some sort of clip you have to remove first, but i haven't found any clip. ?!?!
Old Aug 4, 2005 | 11:16 AM
Mr. Wonderful's Avatar
i tried everything when i did my swap. the only thing that works is a .25 in centerpunch. it came out very easy with that.
Old Aug 4, 2005 | 11:17 AM
Default Re: Bitch pin removal... (...DjEk...)
i still don't know which pin to remove
me dumb.
Old Aug 4, 2005 | 11:18 AM
AlpineInstaller's Avatar
Check this link... http://www.sears.com/sr/javasr...67000
You can find it at the local sears.
Lemme get you a pic, BRB..
Old Aug 4, 2005 | 11:20 AM
dwnthehatch's Avatar
Go to where the linkage mounts to the tranny. Pull the rubber boot back. Remove the metal C-clip. Pound out the pin.
Old Aug 4, 2005 | 11:21 AM
The pin is number 28 and the clip is number 1. I always make sure to put number 1 back but a bunch of cars I have worked on don't have it. There is also a boot that needs to be pulled back from the trans to expose this ****. Good luck!
Old Aug 4, 2005 | 11:22 AM
Default Re: Bitch pin removal... (AlpineInstaller)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AlpineInstaller &raquo;</TD></TR><TR><TD CLASS="quote">Check this link... http://www.sears.com/sr/javasr...67000
You can find it at the local sears.</TD></TR></TABLE>
I have a punch set already. I just don't know where the actual bitch pin is located. I thought i did, but i was completely wrong.
Check this link. The clip is number 1. And the pin is number 22. Please note that there is a rubber boot around the clip that you have to move back first.
http://www.hondaautomotivepart...LEVER
HTH
JCracer723's Avatar
https://honda-tech.com/zerothread?id=1314359
do a better search next time
Old Aug 4, 2005 | 11:23 AM
HondaFanatic708
That's the picture I was looking at except the pin is #28...
Old Aug 4, 2005 | 11:24 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by transpar_nt &raquo;</TD></TR><TR><TD CLASS="quote">
</TD></TR></TABLE>You know in the parts description they actually call it the bitch pin, JK. Look at the pics/links we'have posted, it's right there. For some reason none of them ever show the rubber boot.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaFanatic708 &raquo;</TD></TR><TR><TD CLASS="quote">The pin is number 28 and the clip is number 1. I always make sure to put number 1 back but a bunch of cars I have worked on don't have it. There is also a boot that needs to be pulled back from the trans to expose this ****. Good luck!</TD></TR></TABLE>
****. No wonder i couldn't find it! The pin isn't even there!!! Or the clip. Now it all makes sense. The integra I'm pulling from looks old, but it has low low mileage. I guess the motor was swapped in already... Well, thanks guys
Old Aug 4, 2005 | 11:25 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AlpineInstaller &raquo;</TD></TR><TR><TD CLASS="quote"> HondaFanatic708
That's the picture I was looking at except the pin is #28... </TD></TR></TABLE>Yeah I just grabbed it off http://www.acuraoemparts.com because their parts browser isn't secure so you can link the images..
Old Aug 4, 2005 | 11:27 AM
****. No wonder i couldn't find it! The pin isn't even there!!! Or the clip. Now it all makes sense. The integra I'm pulling from looks old, but it has low low mileage. I guess the motor was swapped in already... Well, thanks guys</TD></TR></TABLE>Oh dam, that is no good. I couldn't see how that car could even be shifted for long without issues. Make sure to at least replace the pin, Honda part number 90751-S04-000.
Old Aug 4, 2005 | 11:28 AM
Thanks. I'll be sure to pick one up.
Ef4doorwagon
13
Sep 17, 2014 09:25 AM
migs
Aug 21, 2006 08:26 PM
RAB
15
Sep 18, 2004 09:03 AM
mykem
19
Aug 15, 2004 02:00 PM
Steve Berman
12
Feb 19, 2003 07:30 AM
