Install Cost??
Old Aug 4, 2005 | 10:25 AM
runevil12's Avatar
Default Install Cost??
I like to wrench my own stuff as much as possible, but this project seems a little tough. i'm buyin the spoon sports engine rebuild kit, which comes with a crankshaft, connecting rods, pistons, rings, and head gasket. any rough ideas on how much a normal engine shop would charge to install all this stuff??
much thanks
Old Aug 4, 2005 | 11:08 AM
Lewdin' Incognito's Avatar
Default Re: Install Cost?? (runevil12)
Ouch. That's about as exact an amount as I can give.
The one time I didn't do the work myself, I got raped for $1800 and my car blew the head less than a week later.....never again.
Besides, pick up a manual and a couple friends - you'll know the engine inside and out! Cheaper labor, and if anything gets fucked, you know who did it!
Old Aug 4, 2005 | 03:49 PM
unknown0001's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by runevil12 &raquo;</TD></TR><TR><TD CLASS="quote">I like to wrench my own stuff as much as possible, but this project seems a little tough. i'm buyin the spoon sports engine rebuild kit, which comes with a crankshaft, connecting rods, pistons, rings, and head gasket. any rough ideas on how much a normal engine shop would charge to install all this stuff??
much thanks</TD></TR></TABLE>
Get some knowledgeable friends over and do it over a weekend. It's a good amount of work but nothing impossible. Don't cut corners or cheap out on small things and everything will go properly
Old Aug 7, 2005 | 03:27 PM
biotech0123's Avatar
Default Re: Install Cost?? (Mr.RHTuner)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.RHTuner &raquo;</TD></TR><TR><TD CLASS="quote">
Get some knowledgeable friends over and do it over a weekend. It's a good amount of work but nothing impossible. Don't cut corners or cheap out on small things and everything will go properly </TD></TR></TABLE>
Get a helms and do it yourself that way you know exactly whats going on with everthing. Its easy just take your time and you'll be fine, just ge the block preped by a good machine shop and check their work when done. Plasigauge will be you best friend.. But if you dont feel comfortable with all this you can pay around 1500 to bout 1800 to do it right, if the shop gives a damn.. Good luck dude
bigislandc2
Oct 17, 2006 09:34 PM
whitetyper
Sep 2, 2004 09:15 AM
p1ccoloz
Feb 7, 2004 08:46 PM
GruvyTune
Jun 2, 2002 03:34 PM
976
Oct 8, 2001 04:52 PM
