Building a log style turbo manifold...Quick question?
Old Aug 3, 2005 | 08:05 AM
Keyhole's Avatar
Default Building a log style turbo manifold...Quick question?
I'm building a log style turbo exhaust manifold and I'm kind of stuck on how to make one part of it. I'd like to build a base underneath the turbo flange like the one in this picture.
I'm sure there are a couple different ways, if anyone can point me in the right direction it would be much appreciated!
Also whats the best way to go about notching the base once its built in order to fit onto the pipe fittings properly?
Thanks!
Modified by Keyhole at 11:17 AM 8/3/2005
Old Aug 4, 2005 | 12:15 AM
silly sohc's Avatar
Default Re: Building a log style turbo manifold...Quick question? (Keyhole)
For notching the base, I've used square tubing with a hole saw to the size of the pipe. then band saw to the depth you need it after shaped. I've used the end mill to get real accurate if there are angles involved, but a hole saw shoud do you fine. That may help your other question... from what I can tell from your pic.
Old Aug 4, 2005 | 04:12 PM
92CHB's Avatar
i got a flare adapter from mcmastercar.com....worked great
Old Aug 4, 2005 | 07:12 PM
AutoLab's Avatar
Default Re: (92CHB)
sounds like youre asking for a radius plate. this place sells them
http://www.jgstools.com/turbo/index2.html
HTH
Old Aug 4, 2005 | 08:13 PM
beepy's Avatar
Default Re: (AutoLab)
Yeah, those are easy enough to make with a grinder, boring bar, lil' jigger or otherwise. Just a piece or rectangular tubing with round notches cut out.
Old Aug 4, 2005 | 08:24 PM
LostCRX's Avatar
Default Re: (beepy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beepy &raquo;</TD></TR><TR><TD CLASS="quote">Yeah, those are easy enough to make with a grinder, boring bar, lil' jigger or otherwise. Just a piece or rectangular tubing with round notches cut out.</TD></TR></TABLE>
An angle grinder should make a quick job outta that.
Old Aug 5, 2005 | 02:07 AM
cua0's Avatar
i use 3x2 3/16 HSS tubing.
Old Aug 12, 2005 | 05:23 AM
Keyhole's Avatar
Default Re: (cua0)
Thanks for the help guys
One more quick question, do you usually use 90's and T's with a 2.25" radius or a 1.5" radius? I believe 2.25" is the way to go...just want to double check.
Thanks!
ef8_eg6
Apr 15, 2008 09:54 AM
atutt
Welding / Fabrication
19
Nov 2, 2006 09:34 AM
pagong
Apr 11, 2004 12:28 PM
SIRX
Apr 23, 2002 07:18 AM
