brakes feel real wierd.
Old Aug 2, 2005 | 08:37 PM
mrdeadman's Avatar
They let me pick
Default brakes feel real wierd.
so im out driving just now and out of nowhere my front brakes feel like they're grinding. there aren't any screeching noises either. maybe i was just paranoid but also there was a sort of burning smell inside the car as well. does anyone know what this is? it's dark now and my brakes are hot so ill check em tomorrow. anyone have any ideas?
Old Aug 2, 2005 | 08:50 PM
OsNApArAvEr's Avatar
id have your rotors checked out
Old Aug 2, 2005 | 09:02 PM
Backk InTheDA's Avatar
I hate everything
Default Re: (OsNApArAvEr)
When you brake, does the wheel itself kind of shake back in forth? If it does your rotors are warped. That doesnt really explain the burning, maybe you got something on your rotors?
Old Aug 2, 2005 | 09:06 PM
mrdeadman's Avatar
They let me pick
Default Re: (BuilttB18C5)
the only thing that happens is that the brakes feel like they're grinding. kind of like right after you wash your car, but worse. the rotors don't have any grooves in them or anything either.
Old Aug 2, 2005 | 09:08 PM
rocketfuelcerx's Avatar
Default Re: brakes feel real wierd. (mrdeadman)
Do you hear the grinding or do you feel it in the peddle. If it is pulsating you may have dirty *** brake fluid and/or air in the brake system. Check to see if the brake pads shims(metal brackets are in place correctly) Seems like your brake pads are worn past the sensor that squeeks...
Old Aug 2, 2005 | 09:15 PM
mrdeadman's Avatar
They let me pick
Default Re: brakes feel real wierd. (rocketfuelcerx)
they never squeeked before though and this just now started happening, i can feel it "grind" but not pulsate. idk, you might be able to hear it as well
Old Aug 3, 2005 | 12:08 AM
ohsnapzafingcu's Avatar
I serve phở for my babies
if it feels like a grind.. you probly ate all ur brake pad away
Old Aug 3, 2005 | 07:28 AM
. a d a m's Avatar
Default Re: brakes feel real wierd. (ohsnapzafingcu)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ohsnapzafingcu &raquo;</TD></TR><TR><TD CLASS="quote">if it feels like a grind.. you probly ate all ur brake pad away</TD></TR></TABLE>
I find that very hard to believe if he heard no prior squeaking or squealing.
gohonda
May 15, 2009 08:27 AM
jjohn6438
Honda Civic (2001 - 2005)
32
May 11, 2009 05:43 PM
mrdeadman
Sep 24, 2005 08:15 AM
ninor
Acura TSX
12
Jan 17, 2005 08:24 AM
digital sol
Oct 31, 2004 02:31 PM
