changing head... coolant in block??
Old Aug 1, 2005 | 06:39 PM
shreddinryguy's Avatar
Default changing head... coolant in block??
Ok, im replacing my head and i drained all the fluids but when i popped the old head off a ton of coolant went into the block around the cylinder walls. Is there a way to get the coolant out of there or can i leave it? I tried just using paper towels but can't get that much doing that. If i take the plug out in the front of the block will it drain this coolant?
Old Aug 1, 2005 | 06:46 PM
CmptchAV6's Avatar
Default Re: changing head... coolant in block?? (shreddinryguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shreddinryguy &raquo;</TD></TR><TR><TD CLASS="quote">Ok, im replacing my head and i drained all the fluids but when i popped the old head off a ton of coolant went into the block around the cylinder walls. Is there a way to get the coolant out of there or can i leave it? I tried just using paper towels but can't get that much doing that. If i take the plug out in the front of the block will it drain this coolant?</TD></TR></TABLE>
I would dry it off the piston tops to the best of your ability and I would pull the oil pan off as well as it might have gone in there.
Old Aug 1, 2005 | 07:18 PM
Default Re: changing head... coolant in block?? (CmptchAV6)
I already cleaned the pistons and dried them up really good. Im going to take the oil pan off and clean that too but how do i get the coolant out from behind the cylinder walls.
Old Aug 1, 2005 | 07:31 PM
PogKai's Avatar
there's a big bolt front the engine (rear-below the header). that's the coolant drain bolt.
OH_1fstgsr
14
Jul 21, 2008 06:03 PM
gotboost562
Apr 1, 2007 07:31 AM
1bar_ek
May 7, 2005 07:57 AM
TEXN3
Jan 24, 2004 04:33 PM
3rdGteg
Oct 24, 2002 05:30 AM
