dyno graph of h22 with sc63 turbo
ONLY 5hrs? jeff can crank out stuff WAYY faster than that...... were you having troubles with something?? you should be able to crack 550 at least with a proper setup and that turbo
EDIT: just noticed you said JAMES evans.......
The torque drops fast i know but with more boost i think it will hold alot longer trough the powerband. as far as et goes i dont know because i still need to get my DR from the shop. but i guess i should be in the mid to low 13s or if lucky high 11s i hope.
