Just FAILED smog at State REFEREE with a B18B, need help with the numbers.
Old Aug 1, 2005 | 09:06 AM
415Hatch's Avatar
Default Just FAILED smog at State REFEREE with a B18B, need help with the numbers.
I got a 00 B18B in my hatch with OBD1 ecu, harness, intake manifold, and dizzy. I went to BAR it today and failed. Here are the numbers that failed. IF u can help me pin point the problem it would be great. Keep in mind i have one back injector.
I know that the NO is do to the CAT going bad. Help me find the problem to the HC and CO. I m thinking its do to the bad injector??? or something else.
15 mph HC (PPM) - CO (%) - NO(PPM)
MAX=121 MEAS=131 MAX=.76 MEAS=.91 MAX=807 MEAS=2757
25 MPH
MAX=96 MEAS=109 MAX=.65 MEAS=.68 MAX=746 MEAS=1775
Old Aug 1, 2005 | 09:12 AM
temp's Avatar
Default Re: Just FAILED smog at State REFEREE with a B18B, need help with the numbers. (415Hatch)
um what kind of car is this in
Old Aug 1, 2005 | 09:13 AM
SYTFU Tommy.'s Avatar
Default Re: Just FAILED smog at State REFEREE with a B18B, need help with the numbers. (temp)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 415Hatch &raquo;</TD></TR><TR><TD CLASS="quote">I got a 00 B18B in my hatch with OBD1 ecu, harness, intake manifold, and dizzy. I went to BAR it today and failed. Here are the numbers that failed. IF u can help me pin point the problem it would be great. Keep in mind i have one back injector.
25 MPH
MAX=96 MEAS=109 MAX=.65 MEAS=.68 MAX=746 MEAS=1775</TD></TR></TABLE>
Old Aug 1, 2005 | 09:46 AM
TunerN00b's Avatar
That high of an HC count is either running really rich, or a failing cat, or both. Running too rich for too long will kill a cat, btw. NOx that high can either be really high combustion temps, or a failing cat, or removing the EGR on a car with an older style cat that doesn't work on NOx (I doubt that applies here).
Old Aug 1, 2005 | 10:02 AM
temp's Avatar
Default Re: Just FAILED smog at State REFEREE with a B18B, need help with the numbers. (tngay)
thanks bub but it DOESNT SPECIFY THE ******* YEAR
Old Aug 1, 2005 | 11:33 AM
415Hatch's Avatar
im going to change out the bad injector with a injector from a D16Z6. change out the cat with a new one from auto zone. AND maybe change out the o2 sensor just to be on the save side. DO U GUYS THINK I WILL PASS IF I DO ALL THAT???
Old Aug 1, 2005 | 11:44 AM
temp's Avatar
Default Re: (415Hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 415Hatch &raquo;</TD></TR><TR><TD CLASS="quote">im going to change out the bad injector with a injector from a D16Z6. change out the cat with a new one from auto zone. AND maybe change out the o2 sensor just to be on the save side. DO U GUYS THINK I WILL PASS IF I DO ALL THAT???</TD></TR></TABLE>
check you PM
Old Aug 1, 2005 | 01:56 PM
PandaBear's Avatar
Default Re: (temp)
OBD1 in 00 chasis will not pass
Old Aug 1, 2005 | 02:19 PM
temp's Avatar
Default Re: (PandaBear)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PandaBear &raquo;</TD></TR><TR><TD CLASS="quote">OBD1 in 00 chasis will not pass</TD></TR></TABLE>
thats why i asked the year, but it is in an EG hatch
Old Aug 1, 2005 | 03:08 PM
415Hatch's Avatar
no , obd2 motor converted to obd1 in a eg shell
AdrenalineAngel
Oct 31, 2012 09:22 PM
AdrenalineAngel
Oct 27, 2012 08:25 PM
JunTec
Jan 26, 2008 09:57 PM
415Hatch
Jul 8, 2005 01:58 PM
effinnwackk
21
Jul 1, 2005 05:50 AM
