I need help PLEASE!!!!!!!
My hood is stuck and won't open. Does anyone have any ideas on how to open it? The cable is not broken from what I can tell, I tried to pull it with pliers but it did not work. Any help would be appreciated greatly before I have to take it to the dealer.
i'll tell ya what i did...
i got under the car...
pulled the radiator off the lower mounts...
i reached way the f up there scraping my hand along the way...
basically feeling around blind...
you find the correct lever towards the bottom/center of the mechanism...
and snafoo !!!
good luck
and snafoo !!!
good luck
once it comes off once...
(if its like mine)...the cable keeps falling off the mechanism
it will come off again...
and i had to use the same method each time...
so i ziptied the cable towards the nose as close to where it attaches to mechanism as possible...
you could also jbweld it to the mechanism...etc...
**** all the haters
**** all the haters
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by digitalcongo »</TD></TR><TR><TD CLASS="quote">**** all the haters
w0rd!
w0rd!
My cable doesnt work well either, have u checked the lever for opening ur hood. Mine is extremely hard to open even with pliers, i just usually pull the cord as hard as i can and it persuades it to move... if it is totally binding up on u..i would look at how the cable is running underneath ur car and see if it is pulled off and getting slack in the line...if it is, well, sorry i really dont know what to do after that....o well good luck
akaEsCo01
May 31, 2004 02:55 PM
drjondurst
Mar 29, 2003 06:34 PM
