Fabricating Harness Bar for a del sol
Old Jul 31, 2005 | 01:38 PM
94turbodelsol's Avatar
Default Fabricating Harness Bar for a del sol
Does anyone know if a company makes a harness bar for a del sol? Is there anyone out there that has fabricated one for their del sol? possibly any pics available? My buddy and I have the tools to make one, but before we start cutting and welding i'd like to get some ideas from some members. Thanks
Old Jul 31, 2005 | 08:07 PM
Bakeoff's Avatar
Default Re: Fabricating Harness Bar for a del sol (94turbodelsol)
I just took mine out to start building my cage. I'll see if I can post some pictures tomorrow.
Old Aug 1, 2005 | 08:24 AM
Del Sol SiR's Avatar
here is some idea: https://honda-tech.com/zerothread?id=1266429
maybe this one can be modified to be an actual harness bar.
Old Aug 1, 2005 | 08:42 AM
cstay's Avatar
Default Re: (DELSOLEMITE)
il get some pictures of the one i made i would sell them but i cant take the reliablilty if somone got hurt in a accident and my restraint system was in the car but il give you the most help that i can
Old Aug 1, 2005 | 09:05 AM
turbohappy's Avatar
I designed and produced the "happy" bar mentioned in that thread. Can't seem to find my good pictures, I'll keep looking.
Old Sep 22, 2005 | 12:42 PM
sleepless247's Avatar
Default Re: (turbohappy)
Why aren't you still making them? I would deefinately buy one from you.
Old Sep 25, 2005 | 12:55 PM
quisp's Avatar
Default Re: (sleepless247)
i have a harness guide bar forsale. $95 shipped. chromoly tubing, made by Stable Energies.
Old Sep 25, 2005 | 01:39 PM
dfoxengr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbohappy &raquo;</TD></TR><TR><TD CLASS="quote">I designed and produced the "happy" bar mentioned in that thread. Can't seem to find my good pictures, I'll keep looking.
did you find them?
Old Nov 5, 2005 | 03:11 PM
Outkasted24's Avatar
Default Re: (quisp)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by quisp &raquo;</TD></TR><TR><TD CLASS="quote">i have a harness guide bar forsale. $95 shipped. chromoly tubing, made by Stable Energies.
I know it's been a while, But do you still have this for sale?
Any Pics?
IM me
Thanks, -Jeff
Old Nov 6, 2005 | 08:29 AM
quisp's Avatar
Default Re: (Outkasted24)
still in my car. i'll get a pix for u later today.
Old Nov 6, 2005 | 09:50 AM
Default Re: (quisp)
Cool!
Old Nov 7, 2005 | 08:44 AM
quisp's Avatar
Old Nov 7, 2005 | 10:44 AM
solsurvivor's Avatar
Default Re: (quisp)
my solution:behind the cage was a brace welded from side to side to attach the harness to. trying to find a pic of the brace itself...
Old Nov 7, 2005 | 03:02 PM
JCracer723's Avatar
Default Re: (solsurvivor)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by solsurvivor &raquo;</TD></TR><TR><TD CLASS="quote">my solution:behind the cage was a brace welded from side to side to attach the harness to. trying to find a pic of the brace itself...
so how good did that cage help you with body roll??...
Old Nov 8, 2005 | 07:40 AM
Default Re: (JCracer723)
not so much the cage, but the brace was what did wonders.........I braced it from left to right and on that brace, I made 3 attachments downwards at an angle of 45 degrees towards the front and down, so it could also be covered up with panels since the rear sections of plastic no longer fitted.
Old Nov 8, 2005 | 08:58 AM
JCracer723's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by solsurvivor &raquo;</TD></TR><TR><TD CLASS="quote">not so much the cage, but the brace was what did wonders.........I braced it from left to right and on that brace, I made 3 attachments downwards at an angle of 45 degrees towards the front and down, so it could also be covered up with panels since the rear sections of plastic no longer fitted.</TD></TR></TABLE>
i see.. im trying to find a solution to the body flex.. i know a cage its the solution but im 6 feet tall and i have a hard time gettin in and out of the car as is.. plus i dont want to be hittin myself everytime while drivin with the damn cage.. so i will try to find some points where i can brace the body.. or the cabin since thats the weakest flex point
Old Nov 8, 2005 | 12:11 PM
Importordomestic's Avatar
stitch weld the frame---- that will fix the body flex. but it requires alot of work and a couple of months with a shell of a car on 2 engine stands!
that is the ultimate solution combined with a roll cage.
Old Nov 11, 2005 | 12:21 PM
JCracer723's Avatar
is there anyway u can post close up pics? interested on where u attached the bars to..
Old Nov 11, 2005 | 12:23 PM
JCracer723's Avatar
Default Re: (Importordomestic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Importordomestic &raquo;</TD></TR><TR><TD CLASS="quote">stitch weld the frame---- that will fix the body flex. but it requires alot of work and a couple of months with a shell of a car on 2 engine stands!
that is the ultimate solution combined with a roll cage. </TD></TR></TABLE>
well thats a debate.. some people say some say
Old Feb 7, 2006 | 09:12 PM
JDM-Punk's Avatar
bump... i need/really want a harness bar
Old Feb 14, 2006 | 07:34 PM
eg2rs's Avatar
Default Re: (IknowYou)
bump to keep it up because this is the reason i am on here tonight. I have a benen harness bar but i would not put a harness on it. More of a stiffening bar but does not really do much there either. I was thinking of a rear cage like the one posted but have bars run from there to the front with a cage under the dash, along the (c?) piller near the floor on the sides below the door line then welding in tie plates from the bar to the c pillers. then fill the frame with the structural foam. good luck
Old Feb 15, 2006 | 06:39 AM
JDM-Punk's Avatar
Default Re: (eg2rs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg2rs &raquo;</TD></TR><TR><TD CLASS="quote">bump to keep it up because this is the reason i am on here tonight. I have a benen harness bar but i would not put a harness on it. More of a stiffening bar but does not really do much there either. I was thinking of a rear cage like the one posted but have bars run from there to the front with a cage under the dash, along the (c?) piller near the floor on the sides below the door line then welding in tie plates from the bar to the c pillers. then fill the frame with the structural foam. good luck</TD></TR></TABLE>
why wont you put harness's on it?... im thinking about makin my own and have it go from the upper seat belt bolts to the lower ones... basically the one i wanna make want it to look something like this
__
Old Jan 14, 2007 | 05:54 PM
Del Sol on Steroids's Avatar
Hey, are you still selling?
Old Jan 16, 2007 | 12:56 PM
Bakeoff's Avatar
Default Re: (Del Sol on Steroids)
before you, the last post was 11 months ago.... PMing him might work better.
check out http://www.solsociety.com and see if you can find anything.
Old Mar 16, 2007 | 11:39 AM
rex1991's Avatar
Default Re: (Bakeoff)
any updates on this bar?
obuhmyuh
Jun 15, 2008 09:58 AM
Del Sol on Steroids
Feb 20, 2007 05:34 AM
clm
Jun 14, 2003 11:11 PM
