Replaced Blownheadgasket, now engine won't run????
Old Jul 30, 2005 | 06:38 PM
JDMCivicEF9's Avatar
Default Replaced Blownheadgasket, now engine won't run????
Well I got a 94 Civic LX that had a blown headgasket. I took the head to a machine shop to see if it isn't warped. It turns out the head is ok. So I replace the headgasket, timing belt, and water pump since everything is apart. I've got everything back together and torqued the head. Now heres where it gets confusing. The car cranks and turns over, but it won't completely run. 1st) I've found out the cam gear wasn't lined UP. Fixed that. 2nd) I lined the crank pulley to TDC. Fixed that. Still it cranks and turns over, still not completely running. Now I'm confused. Doubled checked everything. I got spark and fuel. What can be wrong or what did I do wrong?
Old Jul 31, 2005 | 06:00 AM
sik96teg's Avatar
Default Re: Replaced Blownheadgasket, now engine won't run???? (JDMCivicEF9)
um the only thing i could say is grab ur helms if u have one and start going over everthing to ensure its all hooked up right. set ur crank and cam to tdc pull ur dizzy cap and look to see if the rotor is pointing to the #1 point. There are so many possabilites. hope ur timing wasnt off too bad were u could have bent your valves.
Old Jul 31, 2005 | 08:10 AM
PrettyLude's Avatar
its got to be your timing
Old Jul 31, 2005 | 08:38 AM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMCivicEF9 &raquo;</TD></TR><TR><TD CLASS="quote"> 1st) I've found out the cam gear wasn't lined UP. Fixed that. 2nd) I lined the crank pulley to TDC. Fixed that. </TD></TR></TABLE>
Do you have both of them lined up at the same time?
Old Jul 31, 2005 | 09:42 AM
1700anddroping's Avatar
are you n/a..or turbo since you did not state.
if you blowed a head gasket...how can the head not be warped.how do you not know if you do not have bent valves.how do you know if your even in time.get it in time then do a compression check that will tell the story.
harv
Old Jul 31, 2005 | 04:08 PM
sik96teg's Avatar
If he wants to know if he has bent valves do a leak down test not a compression test that majority of the time wont tell u shiat but your rings are good.
Old Jul 31, 2005 | 04:21 PM
Default Re: Replaced Blownheadgasket, now engine won't run???? (sik96teg)
they are basically the same thing just have different names....if the VALVES ARE BENT...THE COMPRESSION WILL BE VERY LOW...if not zero.and as like you like to say.leak down.if everything is fine meaning valves...put a tea spoon of oil in and see if that raises the compression...if it does then your rings are bad but you could have other problems,like cracked ring lands.
short and simple do the COMPRESSION CHECK AND SEE IF IT STARTS GOING DOWN."leaking down".
Old Jul 31, 2005 | 07:00 PM
Default Re: Replaced Blownheadgasket, now engine won't run???? (1700anddroping)
Its NA actually, just my girls car. Well I checked and line up the cam gear with the head as stated in the Helms and lined up the crank pulley to TDC before putting the timing belt on. I did this 3 times to make sure! Still the out come is the same. Motor cranks and turns over, but not running. Also I notice when I'm cranking it, a friend of mine can hear it backfire through the intake. I even replace the spark plugs with new ones, they turn black soaked with a little gas after a few cranks. What can that be?
Old Jul 31, 2005 | 07:05 PM
sik96teg's Avatar
i only said that because my boy did a compression test on his lude came out perfect then did a leak down test and found he had a few bent valves and a leak down test is more specific in regards to finding exactly where the leak is. Also they are not the same in any way exept they test the amount of air in the chambers.
Old Jul 31, 2005 | 07:07 PM
sik96teg's Avatar
what about the dizzy did u make sure u put that on right
Old Jul 31, 2005 | 07:13 PM
Yeah I had it marked before taking it off. You still think its the distributor?
Old Jul 31, 2005 | 07:16 PM
sik96teg's Avatar
what i mean is the grooves on the dizzy that go in the cam could be in the wrong way u see what im sayin
also did u make sure u didnt mix up the connectors for the map and tps
Modified by sik96teg at 5:00 AM 8/1/2005
Old Jul 31, 2005 | 07:21 PM
Oh ok gotcha. Should of double checked my bro's work on that side. Yeah TPS and Map sensor is plugged correctly.
1993 EG Coupe
Aug 18, 2014 09:13 PM
cloudconnected85
Mar 11, 2009 09:05 PM
JDMCivicEF9
Jul 31, 2005 06:50 PM
306gun
11
Nov 13, 2002 09:15 PM
