buying a LS motor
Old Jul 30, 2005 | 04:26 PM
JDM Vision's Avatar
Default buying a LS motor
ok im about to buy a LS motor off of one of my cousins friends soon.. the only thing is its not going to have a tranny with it and ppl are telling me to get a itr tranny ... soo what i want to know is how do i deal with the cable to hydro conversion... the motor is going into a 95 civic dx thanx .
Old Jul 30, 2005 | 04:30 PM
skater5067's Avatar
Default Re: buying a LS motor (JDM Vision)
i dont understand why you would be converting why dont you just get a hydro tranny and it would be fine. well what set up are you going with are you going to turbo later down the road or all motor. for all motor i would go with the hyrdo si tranny they are cheap and have pretty short gears if you want turbo go with a ls tranny hope this helps
Old Jul 30, 2005 | 04:32 PM
JDM-97CX's Avatar
Default Re: buying a LS motor (skater5067)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skater5067 &raquo;</TD></TR><TR><TD CLASS="quote">i dont understand why you would be converting why dont you just get a hydro tranny and it would be fine.</TD></TR></TABLE>
Because he has a cable trans right now.
JDM Vision's Avatar
im going to go turbo on it in the future
Old Jul 30, 2005 | 05:16 PM
ALLMOTA92EG's Avatar
Your 95 dx has a hydro tranny in it right now so you wont need to deal with the conversion.
Old Jul 30, 2005 | 08:16 PM
blackeg's Avatar
Default Re: (jdm92civichb)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm92civichb &raquo;</TD></TR><TR><TD CLASS="quote">Your 95 dx has a hydro tranny in it right now so you wont need to deal with the conversion.</TD></TR></TABLE>
yes, unless previously converted to cable.
dont get an itr tranny, the gearing is too close for a b18b, you will top out somewhere around 115mph in 5th gear. also for the money of an itr tranny wyou can have a ls or maybe even a gsr tranny with a quaife in it. go with the gsr tranny (as i have done) or perhaps an ls trans with a lightweight flywheel to help you rev up faster
Old Jul 30, 2005 | 08:58 PM
street dreams's Avatar
From: chillin in that city called queen creek, but homes the atl
Default Re: (blackeg)
what motor is in your car right now
Old Jul 30, 2005 | 09:09 PM
red-eg6's Avatar
Default Re: (street dreams)
use a b16 they have short gears and do a ls-vtec and use a b16 head
Old Jul 30, 2005 | 09:21 PM
Good ol' Screwtape's Avatar
Multi-paradigm
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackeg &raquo;</TD></TR><TR><TD CLASS="quote">
dont get an itr tranny, the gearing is too close for a b18b....go with the gsr tranny (as i have done) </TD></TR></TABLE>
Did you mean the ITR tranny gearing is too short? Because while GSR gears are actually a little longer than the ITR, they're just about as close, from gear to gear. And actually the GSRs that came with the YS1 trannies have shorter 1st and 5th gears than the ITR trannies and have identical gear ratios for 2nd, 3rd, and 4th gear, reverse, and final drive to the 96-97 spec ITRs trannies.
Old Jul 30, 2005 | 10:11 PM
JDM Vision's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by street dreams &raquo;</TD></TR><TR><TD CLASS="quote">what motor is in your car right now</TD></TR></TABLE>
i have a d15 in the car right now
Old Jul 30, 2005 | 10:26 PM
Hatch It's Avatar
Default Re: (red-eg6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by red-eg6 &raquo;</TD></TR><TR><TD CLASS="quote">use a b16 they have short gears and do a ls-vtec and use a b16 head </TD></TR></TABLE>
YES
Old Jul 30, 2005 | 11:49 PM
FERIOkid's Avatar
Default Re: (Hatch It)
if you want to go boost get an ls tranny with an aftermarket LSD and you will be golden. the b16 will have you topping out at around 120 in 5th.
Old Jul 31, 2005 | 12:08 AM
solfood's Avatar
Default Re: (slowdx9585)
my friend has a built gsr motor with a 62-1/t4 with a b16 lsd trans and he finishes in fourth at rougly 120ish @ 10.9?? i would personally go with the gsr trans over the ls for boost... itr/ctr trans for all motor setup
Old Aug 1, 2005 | 02:50 AM
skater5067's Avatar
Default Re: (solfood)
with boost gsr trannys have probems with traction cuz of the smaller gears i know someone that has this problem
2000dollarzcbs
Oct 4, 2006 04:13 PM
the DA in HONDA
Sep 23, 2004 12:26 PM
Mires
Jan 10, 2003 06:42 PM
See Are X
Apr 14, 2002 09:11 PM
Variance-EJ-6
Oct 21, 2001 03:52 PM
