compression test results 4 boosted b20/vtec tell me what you think .
Old Jul 30, 2005 | 12:00 PM
B20TDC2's Avatar
Default compression test results 4 boosted b20/vtec tell me what you think .
i just did a compression check to see check out things and the results were
4 3 2 1
180 175 175 175
keep in mind this is a 9:1 block with a gsr head . which i believe would get me around a 9.3:1 total compression . not sure though
let me know what you think about the #'s
Old Jul 30, 2005 | 01:43 PM
s2kdre's Avatar
Default Re: compression test results 4 boosted b20/vtec tell me what you think . (B20TDC2)
if its a jdm b20 then its 8:8:1 comp, the usa b20 is 9:2:1 and with a gsr head its the same, good numbers tho.
Old Jul 30, 2005 | 02:51 PM
B20TDC2's Avatar
Default Re: compression test results 4 boosted b20/vtec tell me what you think . (jdmhonda)
its a built block with j.e. 9:1 pistons
Old Jul 30, 2005 | 02:55 PM
non-VTEC's Avatar
sounds about right........my 9:1 B20 pumps out about the same........
Old Jul 30, 2005 | 03:20 PM
B20TDC2's Avatar
Default Re: compression test results 4 boosted b20/vtec tell me what you think . (non-VTEC)
thanks guys
Timothy Yhtomit
Feb 7, 2018 06:42 PM
killer833
Dec 6, 2013 06:21 PM
JDM97EK
Oct 28, 2006 09:12 PM
ILOVEGIRLS
Oct 11, 2001 08:54 PM
