will B20 84mm pistons workon a GSR block if bored to 84mm???
need to know if my B20 JE pistons will work on my GSR block i fi bore it 84mm..does it matter if they are vtec or non vtec pistons...
do a search theres plenty of info on this
you cant bore your gsr to 84mm first of all unless you have the block sleeved
it does matter if they are vtec or non vtec because of the size of the valve reliefs in the pistons vtec heads 33mm valves will hit the piston because it has valve reliefs for 31mm valves
I just bought 84mm pistons for my car and I think the B20 pistons will work in your GSR. They sell them as B series and not individual for each car if that makes sense.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1SiKTeG »</TD></TR><TR><TD CLASS="quote">I just bought 84mm pistons for my car and I think the B20 pistons will work in your GSR. They sell them as B series and not individual for each car if that makes sense.</TD></TR></TABLE>
oh b20 pistons will bolt to his rods fine but they wont fit into his cylinder walls the gsr has an 81mm bore and the b20 has an 84mm bore
your b20 pistons are 84mm...
get your block sleeved to 84mm and the 84mm pistons will work..
84mm=84mm
it doesnt matter what block it is
84mm=84mm
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LG_R32 »</TD></TR><TR><TD CLASS="quote">
oh b20 pistons will bolt to his rods fine but they wont fit into his cylinder walls the gsr has an 81mm bore and the b20 has an 84mm bore </TD></TR></TABLE>
Dude... he asked if he bored it to 84mm, would they fit? READ BEFORE YOU REPLY!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nickG »</TD></TR><TR><TD CLASS="quote">your b20 pistons are 84mm...
84mm=84mm
it doesnt matter what block it is</TD></TR></TABLE>
84mm=84mm
darkintegra
54
Jun 26, 2017 09:19 AM
JCushing
Oct 23, 2002 04:56 PM
