car wont start with new clutch
Old Jul 29, 2005 | 09:53 PM
TEG777's Avatar
Default car wont start with new clutch
got the tranny in, tried to start the car it wouldnt start, it wouldnt even turn or crank, when i push the clutch down it doesnt feel like there is any pressure on it, anyonw know whats up, its a stage 2 clutch
Old Jul 29, 2005 | 10:06 PM
TEG777's Avatar
Default Re: car wont start with new clutch (boostinteg777)
anyone
Old Jul 29, 2005 | 11:07 PM
TEG777's Avatar
help
Old Jul 29, 2005 | 11:44 PM
SlowReaction's Avatar
Check the starter, make sure you hooked up the starter wire.
Old Jul 30, 2005 | 06:18 AM
PrettyLude's Avatar
did you bleed the clutch?
Old Jul 30, 2005 | 07:14 AM
Vp Special K's Avatar
Default Re: (PrettyLude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrettyLude &raquo;</TD></TR><TR><TD CLASS="quote">did you bleed the clutch?</TD></TR></TABLE>
Old Jul 30, 2005 | 09:07 AM
TEG777's Avatar
Default Re: (Vp Special K)
no i did not bleed the clutch
Old Jul 30, 2005 | 09:33 AM
Crazydave's Avatar
Default Re: (boostinteg777)
did you open or undo the clutch lines at all?
did you verify the the push rod is pushing the fork mechanism, and hasn't shot out and gotten lost?
did you connect the ground strap to the tranny?
Old Jul 30, 2005 | 12:19 PM
TEG777's Avatar
got the car to start, but the clutch pedal isnt stiff at all, its a stage 2 clutch
Old Jul 30, 2005 | 02:15 PM
hYbRid_Eg6's Avatar
bleed the clutch, it might have some air in it.
Old Jul 31, 2005 | 08:12 AM
TEG777's Avatar
how many times should i bleed it
Old Jul 31, 2005 | 10:44 AM
Crazydave's Avatar
Bleed it until it feels good
Be careful though.. the resivoir is not that big. you will quickly run out of fluid, I suggest you have a friend help you
Old Jul 31, 2005 | 06:21 PM
JDM_JON's Avatar
Default Re: (Crazydave)
what clutch are you running in your car?
Old Aug 1, 2005 | 09:54 AM
TEG777's Avatar
Default Re: (JDM_JON)
spec
Old Aug 10, 2005 | 08:49 AM
importfan0103's Avatar
so how can you not disconnect the hydro lines and change the clutch.... It makes it so much harder.. bleed the lines definietly. then if the clutch doesn't engage or dis engage completely your clutch slave cylinder isn't pushing the fork in correctly. now this sucks(its happened to me before) now you have to take the tranny back off disconnect the fluid ines for the slave cylinder. remove starter. Make sure the clip is securing around the head of the rod that the fork sits on. push the fork in and out acting as the slave cylinder would. if it moves properly put the tranny back on and you'll be set. remember to re bleed the lines best thing to do i get a hose that just fits on the nipple and long enough so you can have the bottle of dot3 on the ground, fill up resovour and pump clutch till lines complete close nipple up pump some more should stiffen up dramatically if doesn't then you re bleed. Good luck this is all from experience trust me
Old Aug 10, 2005 | 10:24 AM
b18bturbo's Avatar
Default Re: (importfan0103)
is it even turning over the starter if not its your ground wire or the starter singal wire its single wire that runs to the starter. also check your grounds in that area there two of them
vtec25
Aug 4, 2006 10:44 PM
peacexisxfree
May 15, 2006 05:37 PM
TEG777
Jul 31, 2005 10:33 AM
90HcDxR
16
Apr 30, 2005 01:38 PM
TurBoXBirD16
Audio / Security / Video
Mar 5, 2002 09:10 AM
