car wont start with new clutch
Old Jul 29, 2005 | 09:10 PM
TEG777's Avatar
Default car wont start with new clutch
got the tranny in, tried to start the car it wouldnt start, it wouldnt even turn or crank, when i push the clutch down it doesnt feel like there is any pressure on it, anyonw know whats up, its a stage 2 clutch
Old Jul 29, 2005 | 09:22 PM
TEG777's Avatar
Default Re: car wont start with new clutch (boostinteg777)
anyone
Old Jul 29, 2005 | 09:24 PM
FULL-REV's Avatar
did ya put the starter back on ? heh
Old Jul 29, 2005 | 09:29 PM
TEG777's Avatar
Default Re: (hondaevo)
yes i put the starter back on and checked all the sensors, everything is on, i dont get any pressur when i press on the clutch
Old Jul 29, 2005 | 11:07 PM
TEG777's Avatar
help
Old Jul 29, 2005 | 11:19 PM
gsr dood's Avatar
Default Re: (boostinteg777)
doood check the clutch engagement. wen ur foot is on the clutch theres a switch that tells the computer its engaged make sure its engaged. also wen i installed my clutch last week i forgot to fill my clutch back up with brake fluid becaus ei beld it before i installed the clutch soo bleed the lines and the clutch pedal should be nice and tight. also double check that starter there a positive wire that has a butt connecter and make sure u but the ground back on the tranny and it has good connection. im almost certain that its the starter or the clutch. good luck
Old Jul 29, 2005 | 11:21 PM
gsr dood's Avatar
Default Re: (gsr dood)
come to think of it did u install the new throwout bearing and replace it correctly? if u forgot to hook that up right the clutch wont engage properly
Old Jul 30, 2005 | 03:44 AM
saleensolution's Avatar
make sure that you put the spade connector back on to the starter and how did you unhook the slave cylinder? if you broke the line loose from the slave cylinder then your gonna have to bleed it before you get any pressure back in it
Old Jul 30, 2005 | 04:05 AM
yrethguad's Avatar
I'm thinking slave cylinder too. Where is that clutch-starter switch? Doesn't it just detect pedal position? I'm thinking it still should have cranked. You're getting all your dummy lights, right?
Old Jul 30, 2005 | 04:29 AM
Default Re: (yrethguad)
the switch is up under the dash. if you crawl up under the dash you will see it. however you dont ever touch the switch when changing the clutch there fore i would not think that it would be part of the problem. i have done it before where i did not get the single spade wire all the up on to the connector and it wouldnt start. heres a pic in case you get a little confused of what it is.
this is where the wire gets hooked up at (on the starter)
and this is what the connector looks like
good luck
Old Jul 30, 2005 | 09:10 AM
TEG777's Avatar
i will try to bleed the clutch tommarow
Old Jul 30, 2005 | 11:22 AM
projectTeG's Avatar
you connected all the connections on the starter right? all the grounds too?
Old Jul 30, 2005 | 12:19 PM
TEG777's Avatar
the connector shown above wasnt connected, i connected it and the car started, but the clutch isnt stiff at all,
Old Jul 30, 2005 | 02:03 PM
projectTeG's Avatar
that happen to me when i installed my clutch but it was a stock replacement...and after a little time it stiffened back up..iuno that was just me
Old Jul 31, 2005 | 03:47 AM
Default Re: (projectTeG)
did you bleed the clutch at all? try bleeding it and then you should get your stiffness back
Old Jul 31, 2005 | 08:12 AM
TEG777's Avatar
how many time should i bleed it
Old Jul 31, 2005 | 10:06 AM
Endless STi's Avatar
if ur gonna bleed ur clutch. get speed bleeders. they r about 7.00 and well worth it.
Old Jul 31, 2005 | 10:33 AM
ef_you_once_more's Avatar
yea man you need to bleed it until no bubbles come out
MI4$DC5
Apr 15, 2007 09:33 PM
peacexisxfree
May 15, 2006 05:37 PM
TEG777
Aug 10, 2005 10:24 AM
90HcDxR
16
Apr 30, 2005 01:38 PM
TurBoXBirD16
Audio / Security / Video
Mar 5, 2002 09:10 AM
