Brake Problem on EG
Alright I have GSR Brakes all the way around, GSR 1" Master Clyinder, GSR Brake Booster, GSR Front spindles, GSR Rear Trailing arms. Now here is my problem, I recently replaced the Brake booster and the master clyinder and when i step on the brakes, I get pedal pressure off the bat, but once i put more pressure on it, it slowly goes fades, put enough pressure on it and it will fade to the floor. Now Im a ASE cert mechanic, and I know thats cause of a leaky diaphram in the brake booster or bad seals in a master clyinder. But I just replaced those and bled the system like 8 times! im scratching my head... Did i use a wrong componet, maybe im suppose to use a 15/16 Master Clyinder? Help a fellow tech out.
From: With my POS D15B2, Whereever whenever, United States
B what part number is that?
I need one too
You basically need for it to be plug and play a 99-00 si master cylinder and 99-00 si prop valve
thats plug and play into an eg
I need one too
From: San Diego, I miss Chicago, but love SD, CA, US of fuckin A
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MugenHonda »</TD></TR><TR><TD CLASS="quote">B what part number is that?
I need one too
thats plug and play into an eg</TD></TR></TABLE>The Honda part number for the 00Si is 46210-S04-902.
I need one too
EJ2_B16
Aug 20, 2004 02:34 PM
