oil pickup question
Old Feb 19, 2002 | 12:37 PM
Kamin's Avatar
Default oil pickup question
Hey,
as many of you know my vtec dosent work ( https://honda-tech.com/zerothread?id=127578 )
myself and friends have narrowed it down to oil pressure.
so im starting at the bottom and working up (litterally)
my oilpan has a dent about .25-.5 inches all the way around the bottom
i pulled the pan and im curious if the pickup could have been damaged as well
having never done this before i dont know what to look for in a damaged pickup
any information would be helpful
thanks everyone
Joe
Old Feb 19, 2002 | 01:04 PM
Crazydave's Avatar
Default Re: oil pickup question (KAMiN)
well it will be bent.....
it's thin metal so it should be obvious...
Have you put an oil pressure gauge on the car...
also look for chunks of metal when you pull your pan
are you throwing any codes?
Old Feb 19, 2002 | 01:10 PM
fixhondas's Avatar
its possible the oil pan is dented enought to restrict flow to the pickup- did you ever try hooking up 12 volts+ to the vtec solenoid?
Old Feb 19, 2002 | 01:41 PM
Kamin's Avatar
Default Re: oil pickup question (fixhondas)
thats why i posted the link to the other thread
ive done everything short of oil pressure testing because i have no gauge. heres a rundown
no CEL
oil light comes on when car is cold for 10-15 seconds
solenoid is good (12v test)
no open connection to/from ecu on ethire plug so the only thing left is oil related
and yes the pan can be dented enough to cause a lack of oil pressure, its a pretty severe dent. there is a trioval shaped place on the bottom of the pan where the paint is scraped off/dented back down directly over where the pickup should sit.
i took pictures so ill show everyone when i get em developed.
also, does anyone know how much a new pickup would run from honda?
[Modified by KAMiN, 10:43 PM 2/19/2002]
Old Feb 19, 2002 | 06:02 PM
B18C-EJ1
Guest
Posts: n/a
$37 from Acura for the GSR
Old Feb 19, 2002 | 06:38 PM
tinkerbell's Avatar
Default Re: oil pickup question (B18C-EJ1)
does that include the new o-ring?
remember to replace it - even if you dont replace the pick-up.
sounding good KAMiN, hope all goes to plan,
you should be VTECin' soon...
t..
Old Feb 19, 2002 | 08:11 PM
B18C-EJ1
Guest
Posts: n/a
Default Re: oil pickup question (tinkerbell)
No, the gasket is about 1.50
Old Feb 19, 2002 | 08:50 PM
Kamin's Avatar
in the words of jack black from tenacious d
"i did it....i ******* did it...."
MUHAHAHA
its SICK how loud it is and how vtec pulls
it WAS the oilpan
pounded that **** out and vtec screams now.
Old Feb 20, 2002 | 02:35 PM
tinkerbell's Avatar
HAAAAAAAAAAAAAAAAAAAAAAAAA
yay team!
nice how it sounds eh? feels good too!
no need for professionals thanks very much.
t..
h22ek9forme
10
Nov 6, 2007 11:26 PM
sol2hatch
Mar 6, 2006 10:45 AM
HamiltonRex
Oct 10, 2004 12:23 PM
sikek
Aug 10, 2004 05:49 PM
WuRKD b16
Apr 6, 2004 01:20 PM
