Knock sensor control, P28 based Hondata and the J&S safeguard...
Old Feb 19, 2002 | 11:57 AM
Austin's Avatar
Default Knock sensor control, P28 based Hondata and the J&S safeguard...
Since I recently changed my setup from an A'PEXi PowerFC to a P28 based Hondata setup(both of which do not have an active knock retard feature...if you're knocking, the ECU does notretard your timing) and experienced some problems(link here) hooking up my J&S Safeguard I reevaluated my need for another piece of electronics(while I couldn't get everything to work correctly)....but after looking into what the J&S does, and who uses it (the factory Corvette Race Cars that won class @ 2001 24 Hour Le Mans Race, Adam Sawaratari...) I decided that it is better to have this item installed and have a piece of mind then me screwing something up and ending up with some pieces of broken pistons for souverniers.
I found this posted by John @ J&S on ClubSi, though that it would be interesting:
Turbo kits are not "Bolt on Heaven".
Old saying: If a turbo you have tried, then a piston you have fried.
Wouldn't it be nice to not have to worry about a "boost spike", or crap gas, or leaning out?
I put together a home made turbo for my Fiat back in the early eighties. I blew the head gasket at least three times, so someone suggested that I should get the head o-ringed. Then, instead of blowing head gaskets, I started breaking pistons.
It was really a drag, every time you stepped on the gas, you had to strain your ears to listen for detonation, and back pedal it if you thought you heard it, unless there was some turkey alongside, trying to pull you, then, of course, you couldn't back off, you just prayed as the boost came up.
Back then, there weren't any timing computers or fuel controllers. We had to make our own water injection. In the winter we had to walk through six feet of...oh, wrong story.
About that time, Porsche came out with the 944 Turbo. Road and Track magazine said it used Bosch electronics with a knock sensor to retard timing. What was really cool, was that it retarded only the cylinders that were knocking.
That's where I got the inspiration for the SafeGuard. I was an electronics technician in aerospace. I became obsessed with the idea of building my own knock controlled ignition. By then, I had gotten really tired of rebuilding the old Fiat. How much better to have electronics listen for knock for you, and then automatically control the timing?
The SafeGuard was finally brought to market in '91. It's simple in concept, but I had a lot to learn before I had a design that worked.
Everybody says their kits don't ping. Why, then, do engines blow? Anyone that sells you a kit and says you don't need a SafeGuard is just trying to ease the financial pain to make a quick sale.
Yes, we make a profit building them, but they were designed to fix a problem on my own car.
More technical information here
Austin
b18_racer805
Oct 15, 2005 10:38 PM
ghettochild
Nov 3, 2004 08:30 AM
11psiTurboSI
Aug 27, 2003 08:03 PM
brcivic411
Jul 25, 2002 05:57 PM
Austin
Feb 21, 2002 03:34 PM
