is there anyway to add a knock sensor to a p28 w/ hondata
just as the title states im just wanting to know should i go with p28 or p72
for my hondata
for my hondata
Re: is there anyway to add a knock sensor to a p28 w/ hondata (ghettochild)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ghettochild »</TD></TR><TR><TD CLASS="quote">just as the title states im just wanting to know should i go with p28 or p72
for my hondata </TD></TR></TABLE>
if you can find a knock board out of a ecu you can install it in yours but its eisier to get a p72 or p61,pr3 and add the iab if you are using them.
Re: is there anyway to add a knock sensor to a p28 w/ hondata (b18cls1)
When i ordered my s200b from wirespeed lab (about 2 weeks ago), they told me that you can wire the knock sensor into the hondata or something of the sort. I was going to sell my p28 and buy a p72, but they told me i would still be able to wire the knock sensor to the hondata using a p28. I just havent looked very far into it. Hope this helps some. josh
any more info would be a great help... Im probably going to be doing this in about a week
Re: is there anyway to add a knock sensor to a p28 w/ hondata (adictionbass)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adictionbass »</TD></TR><TR><TD CLASS="quote">Hell yeah, you the man! Good lookin out </TD></TR></TABLE>
no prob
no prob
anyone have a diagram of how to wire the knock sensor to a p28 or into the hondata. im in the same boat.
Re: is there anyway to add a knock sensor to a p28 w/ hondata (donkiman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by donkiman »</TD></TR><TR><TD CLASS="quote">anyone have a diagram of how to wire the knock sensor to a p28 or into the hondata. im in the same boat. </TD></TR></TABLE>
which ks?? wether into the p28 or hondata thier both going to go into the ecu
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18cls1 »</TD></TR><TR><TD CLASS="quote">
which ks?? wether into the p28 or hondata thier both going to go into the ecu</TD></TR></TABLE>
that doesnt matter i just need to know this
Re: is there anyway to add a knock sensor to a p28 w/ hondata (Bailhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bailhatch »</TD></TR><TR><TD CLASS="quote">shes garbage huh? Give us the details Mr D.</TD></TR></TABLE>
Honda ECU ignores KS at WOT, and above 5000 rpms. Don't take my word for it, read your Helms. Thusly, factory Honda KS does nothing to safeguard your engine; it trims ignition timing at part throttle cruise to keep combustion temps cool and lower NOx gas emissions. This is especially important on the higher CR VTEC engines; the only engines that got KS until OBD2.
Honda is going after LEV and ULEV spec here, guys... KS is $ to buy, KS ECU is more $ to buy, KS is hassle to wire, and KS is a reoccuring driveability problem when you get a few miles on the system. Look at the phantom knock the DSM guys get.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adictionbass »</TD></TR><TR><TD CLASS="quote">so are you saying it would be a bad idea to run a j&s safeguard?</TD></TR></TABLE>
What is the difference between how a J&S Safeguard and how the Honda ECU reacts to KS input? OIC, fascinating!
the son and the heir
Re: (DaX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DaX »</TD></TR><TR><TD CLASS="quote">J. Davis comes forth with knowledge, sarcasm, disbelief, insight, dickheadedness, and tough love all in one mighty swing. Take this marauder for what you will.</TD></TR></TABLE>
J. Davis is a very knowledgable 'seething jackass.'
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adictionbass »</TD></TR><TR><TD CLASS="quote">i cant tell if this guy is being sarcastic, or being an ***.</TD></TR></TABLE>
come on, is there really a difference? regardless, i believe he would confess to both offenses
