Yay an intermitent code 5
Old Jul 28, 2005 | 09:38 PM
Dancing is Forbidden's Avatar
Default Yay an intermitent code 5
I finally got the car started after using a d16a6 dizzy modded and it run with no codes. I drove it down the street for about 5 minutes, no codes, vtec works its a stout engine. Get back home calm down ( excitement is an understatment) and then start it up and go to check timing.
I start up the car. All is fine. It idles at 750ish and sounds ok. Put the timing light on and get ready to check it and it starts idling funny and then cuts out. Weird. Start it up, same routine. This time I look for codes. Code 5. Hrmmm. Change MAP sensor and it is the same outcome. Weird.
Well here is where it gets more weird. I start it up to move it out of the way and it does the same idling fine and then i put it in gear and move it. Its all good. NO weird idle after Nothing. Shut it down, start it back up and press the gas pedal a few times and its ok again.
So what could it be? I took a very small video of it so you can see what it does after 15 seconds.
http://www.we-todd-did-racing....5NTQx
Thanks for all of your help. If there were an EF-ht forum decal, id rock it. You guys got me this far.
Old Jul 28, 2005 | 09:55 PM
SMZ GSR's Avatar
Default Re: Yay an intermitent code 5 (ih8jdm)
Sorry, just had to come in and say that was funny as ****. Simon just showed me the vid
Old Jul 28, 2005 | 09:57 PM
cedete's Avatar
Default Re: Yay an intermitent code 5 (SMZ GSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SMZ GSR &raquo;</TD></TR><TR><TD CLASS="quote">Sorry, just had to come in and say that was funny as ****. Simon just showed me the vid </TD></TR></TABLE>
ahahah... ill second that. simon just showed me too
Old Jul 28, 2005 | 10:04 PM
Default Re: Yay an intermitent code 5 (cedete)
Oh yeah. Its running rich as hell too.
.DOHChi
Guest
Posts: n/a
lol at your crx. buy my integra and youll be happier
Old Jul 28, 2005 | 10:06 PM
Default Re: Yay an intermitent code 5 (.DOHChi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .DOHChi &raquo;</TD></TR><TR><TD CLASS="quote">lol at your crx. buy my integra and youll be happier</TD></TR></TABLE>If I bought it, Id never get to drive it. Princess would be too busy streetracing.
Old Jul 29, 2005 | 07:19 AM
ttt
Old Jul 29, 2005 | 06:10 PM
Old Jul 29, 2005 | 06:30 PM
EFbomb's Avatar
check tps
Old Jul 29, 2005 | 09:36 PM
Default Re: (EFbomb)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EFbomb &raquo;</TD></TR><TR><TD CLASS="quote">check tps</TD></TR></TABLE>for?
Old Jul 30, 2005 | 05:22 AM
please help!!!
Old Jul 30, 2005 | 11:55 AM
Noone?
Old Jul 30, 2005 | 01:34 PM
DieMaster's Avatar
Needs to be About 20% Cooler
code 5 is a vacume line problem to the map. check to see if there are any holes in the line and it has manifold vackume.
autodriver
Honda CR-V & Element
Nov 9, 2012 07:31 AM
guymosiris
Sep 17, 2007 02:10 PM
xd69
Jun 28, 2005 02:00 PM
DragInteg
Apr 21, 2004 12:09 PM
DragInteg
Apr 21, 2004 07:29 AM
