help with strarting!!!!!
Old Apr 20, 2004 | 07:16 PM
DragInteg's Avatar
From: MY GIRLFRIENDS MOMS HOUSE, NEW BERLIN, WI, USA
Default help with strarting!!!!!
ok here is the deal. brand new motor (built b16)... i went to do the first start on the new motor cranked over fine and started first time, but then the idle dropped off after 5-10 seconds. so go to start it again and does the same thing starts fine but then dies after a few seconds. i did that about 4-5 times all only running for 5-10 seconds.BTW all those times it was throwing a MAP sensor code..... but then it started perfect ran for a good 4-5 mins and was warmed up, still with the map code flashing!! so i shut it off and check for leaks etc, no leaks. i pull the plugs to make sure they are all firing and all look great- also check the timing looks perfect aswell. go to start it up and it does the same thing runs for a few seconds and them dies out, when i went to give it gas it bogs down and still dies. do that 2 or 3 more times with all the same result, it just dies. still throwing the map sensor code. now it wont even run for a few seconds it just cranks and cranks. i put in a half tank of new gas with the same result also tried some "startup fluid" that you spray into the TB but no luck. and did the "ghetto" injector test with a screw driver to the ear with some one cranking the motor, they where all "clicking". also pulled all the wires and checks those all where firing. any one have any ideas???? thanks for your help
its a new map sensor too. but even if it was the map sensor it should still run, just like crap
Old Apr 21, 2004 | 05:31 AM
DragInteg's Avatar
Default Re: help with strarting!!!!! (DragInteg)
COME ON SOMEONE HAS SOME IDEAS
Old Apr 21, 2004 | 07:29 AM
BAZ's Avatar
BAZ
bump.
93sidelsolvtec
Jan 25, 2007 05:37 PM
stocker2shocker91
Dec 20, 2006 05:24 PM
Dancing is Forbidden
12
Jul 30, 2005 01:34 PM
WickedWerx
Oct 28, 2004 07:02 PM
DragInteg
Apr 21, 2004 12:09 PM
