Gauge install help....
Old Jul 28, 2005 | 08:31 PM
Boosted 2L's Avatar
Default Gauge install help....
Just got a a pillar for a 94 civ..4dr lx.. i wanted to know where to tap in the sender wire for the air/fuel guage.. ? i was wondering if i can tap it through the ecu like the dsm guys or do it straight to the o2 sensor?
Old Jul 28, 2005 | 09:14 PM
PURPLETERROR aka BIGMATT's Avatar
Default Re: Gauge install help.... (Boosted 2L)
you realise that gague hooked up to the stock o2 sensor is pretty much useless right?
Old Jul 29, 2005 | 09:40 AM
Boosted 2L's Avatar
Default Re: Gauge install help.... (PURPLETERROR)
my reply to that is, my friend is head strong about putting that and his oil pressure gauge into his car.. n he doesnt want to/has no timeto look up threads on how to do it.. so for me to get him off my case about wiring it.. i figured id ask.,..
Old Jul 29, 2005 | 09:51 AM
Burke's Avatar
Banned
hit it off the ecu, not sure of the pin or hit the white wire, either way its ******* useless on a stock o2
Old Jul 29, 2005 | 12:48 PM
Boosted 2L's Avatar
Default Re: Gauge install help.... (Burke)
thankyou... i was wondering where i can get a ecu pin lay out... i've tried searching a few threads n sites but i can find any thing on a ls ecu
Old Jul 29, 2005 | 01:58 PM
no2unenolife's Avatar
all white wire
Old Jul 30, 2005 | 05:20 AM
d16dcoe45's Avatar
Actually the 4-wire O2 sensors aren't totally useless. They basically work as rich, stoic., and lean indicator. I think one of them the MSD kit is pretty honest. It only has two leds. When one of them lights you are lean, when the other lights you are rich--and when both light you are at stoichiometric...
Old Jul 30, 2005 | 06:14 AM
PrettyLude's Avatar
its the white wire on the o2 sensor itself or the ecu
Old Jul 31, 2005 | 10:03 PM
Boosted 2L's Avatar
Default Re: (PrettyLude)
oh ok thanks alot... i got another ? with the oil pressure gauge install... when placing the sender in with a T any one have issuses with the T breaking at all or did you just put the sender in the location of the stock one?
Old Aug 1, 2005 | 07:39 PM
PrettyLude's Avatar
you need to put the sender at the firewall, the weight of the sender on the block will break over time due to vibration
Zac W.
Apr 26, 2013 04:23 AM
BlUAc
Sep 24, 2006 10:20 AM
CRX SiR T
Feb 16, 2003 10:26 AM
IgniteTeg
Aug 20, 2002 08:13 PM
IgniteTeg
Jul 31, 2002 11:07 PM
