Overheating at stoplight
Hey whats up, i just got a 88 Hatch with a b18b swap, and when i drive on highway my temp is normal, just below the half way mark... sometimes and i mean sometimes at stoplights it will increase all the way up to the red line, once i start moving again it goes back down to normal really quick... Any suggestions on what it might be?? Also this is not an everyday thing its like once a week... One more question i have is my idle is about 750, and jumps to 1.2k rmps allmost sounds like its gonna die somtimes i checked all my vacume lines for leaks and found nothing wrong.. Any suggestions would be great.. I am in Northern VA Area plan on doing some more mods to the car if anyone lives around here and wants to make some $$ lemme know cuz i dont wanna pay shop prices and also want to learn a little bit at the same time!
I'd put money on it being the fan. Mine would do the same thing. Check the fuse, Then if not that there is a relay on the pass. of the engine bay by the battery(that was the problem in my 88std)
Good luck
Good luck
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Proper »</TD></TR><TR><TD CLASS="quote">Then if not that there is a relay on the pass. of the engine bay by the battery(that was the problem in my 88std)Good luck</TD></TR></TABLE> Which item is that exactly, I have two relays located over there.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dr_latino999 »</TD></TR><TR><TD CLASS="quote"> Which item is that exactly, I have two relays located over there.</TD></TR></TABLE>
i beleive its the black one...the one outlined yellow.......the other outlined green is for headlights
Thanks everyone!! I fixed the problem. Today i did a full radiator flush and i tested out the fan and the fan was not running at all once it got over the half way mark. Soo i checked the fuses and the relays and their was no problems.. so i traced the wires from the fan back and found out that they went to a manual toggle switch inside the car and the wire had become disconnected so i hooked the switch back up and now its running great. Thanks again for the advice!
slow_low_eddie
Jan 7, 2014 07:54 PM
phoxking
Apr 4, 2011 09:03 PM
