B16 overheating
Old Jul 28, 2005 | 06:34 PM
cbabyby's Avatar
Default B16 overheating
i have a 93 civic with a b16, when i got on the interstate my car overheated.
my temp gauge says the temperature is fine but all of my water has done boiled out of the radiator.
could it be the thermostat?
could it be the radiator? i still have the factory radiator in the car, should i put a si radiator in it?
Old Aug 4, 2005 | 12:48 PM
edge099's Avatar
Default Re: B16 overheating (cbabyby)
Check your cap out themostat make and check your coolant pressure system
Old Aug 4, 2005 | 05:11 PM
PrettyLude's Avatar
maybe air in the system? a thermostat is only a couple of dollars, you should just go ahead and change it
Old Aug 5, 2005 | 10:23 AM
FairlightRacing's Avatar
Default Re: (PrettyLude)
Change your thermostat and radiator cap. Should fix it.
Old Aug 6, 2005 | 01:25 AM
mrDFWmechanic's Avatar
buy those 2 items and if you have access or know somebody have them pressure check the system and see if it leaks anywhere
Old Aug 6, 2005 | 03:40 AM
Flashmn's Avatar
Default Re: (iROCKtheSOHC)
if the water already boiled out, chances are your headgasket went too.
martiw2
Oct 26, 2008 08:10 AM
soon2bdropped
Jan 15, 2007 03:41 AM
smokerz212
Jan 8, 2007 05:13 PM
ScoobCivic
Nov 19, 2004 09:22 AM
92VtecTeggy
Jun 20, 2003 08:13 AM
