Main Bearing clearances too small
Old Apr 5, 2005 | 10:23 AM
rmcdaniels's Avatar
Default Main Bearing clearances too small
I took my B16A2 block to get bored and honed, but when I got it back the main cap clearances were too small. If the crank is bolted in and torqued down, then it won't budge. There's only about 10K miles on the crank and bearings, and I got the block bored because I melted the pistons a bit, but the machine shop says they did nothing to the bearing journals.
What would cause the clearance to get smaller?
Old Apr 6, 2005 | 03:05 AM
NJIN BUILDR's Avatar
Default Re: Main Bearing clearances too small (rmcdaniels)
I know its basic but make sure the caps are in the correct positions and facing the correct direction.
Glenn
Old Apr 6, 2005 | 03:10 AM
rmcdaniels's Avatar
I think we figured it out. I went back to the shop and talked to the owner. Apparently when they bore a block they set it on a round metal bar on the main bearing journals and it will sometimes scuff them a bit, causing the bearings not to seat properly. He said most people don't notice it because they don't measure the clearances down to .0005" like the guy I'm having assemble the bottom end, and that once it gets running it takes down the high spot pretty quickly. He said we could buff it out with a very mild abrasive or a fine circular file.
Old Apr 6, 2005 | 11:33 AM
tgreaves's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rmcdaniels &raquo;</TD></TR><TR><TD CLASS="quote">I think we figured it out. I went back to the shop and talked to the owner. Apparently when they bore a block they set it on a round metal bar on the main bearing journals and it will sometimes scuff them a bit, causing the bearings not to seat properly. He said most people don't notice it because they don't measure the clearances down to .0005" like the guy I'm having assemble the bottom end, and that once it gets running it takes down the high spot pretty quickly. He said we could buff it out with a very mild abrasive or a fine circular file.</TD></TR></TABLE>
Now thats scary..
Old Apr 10, 2005 | 07:47 PM
rmcdaniels's Avatar
We put it together and fired it up, it ran for about five seconds before it siezed. It's coming out to get line honed.
Old Aug 6, 2005 | 04:13 AM
EnzoSpeed's Avatar
Default Re: (rmcdaniels)
I know this is old, but what the f*ck? The motor seized!? Did that shop offer to fix it?
Was no one else bothered enough by this situation to comment back in April?
ziggy3784
Apr 30, 2009 07:48 AM
jordan2305
Mar 18, 2008 06:38 PM
93preludes
Oct 24, 2005 10:15 PM
mattb16a1civic
May 16, 2005 02:24 PM
Jared
Jun 24, 2001 08:45 AM
