white smoke helppp!
Old Jul 28, 2005 | 10:53 AM
HBK_DAVIDDD's Avatar
Default white smoke helppp!
my 90 si is throwing a bunch of white smoke out of the exhaust when in first gear and high RPM's... before, i was having problems with the car not starting... turns out, that was the rotor in the distributer. got that fixed and i am now having this problem. The car does not start easilly after being drivin for more than half an hour. (it just cranks) then when it does start, it throws alot of white smoke! idk what the problem is! PLEASE HELP!
(btw... it is a stock d16a6)
Old Jul 28, 2005 | 10:59 AM
dr_latino999's Avatar
Default Re: white smoke helppp! (dAviD_eFsquaD)
White smoke --> Coolant --> Bad Headgasket, Bad Intake Manifold Gasket, Cracked Head
White/Blue Smoke --> Oil --> Piston Rings, Valve Seals
Black Smoke --> Unburnt fuel --> ECU with CEL on, motor running super rich
Old Jul 28, 2005 | 11:01 AM
BoostdRex's Avatar
Default Re: white smoke helppp! (dr_latino999)
Yup, as dr-latino said, that pretty much explains it...
Old Jul 28, 2005 | 11:02 AM
explictness's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dr_latino999 &raquo;</TD></TR><TR><TD CLASS="quote">White smoke --&gt; Coolant --&gt; Bad Headgasket, Bad Intake Manifold Gasket, Cracked Head
White/Blue Smoke --&gt; Oil --&gt; Piston Rings, Valve Seals
Black Smoke --&gt; Unburnt fuel --&gt; ECU with CEL on, motor running super rich</TD></TR></TABLE>
CRX Toad's Avatar
Old Jul 28, 2005 | 12:36 PM
jacobforcecrx's Avatar
Black Smoke --&gt; Unburnt fuel --&gt; ECU with CEL on, motor running super rich</TD></TR></TABLE>headgasket
Old Jul 28, 2005 | 12:39 PM
Ass$nyper's Avatar
Pirate General...YARRRR
Default Re: white smoke helppp! (jacobforcecrx)
head to honda order a z6 headgasket
Old Jul 28, 2005 | 11:07 PM
Default Re: white smoke helppp! (Ace$nyper)
thnx for teh help guys! now its time to wrench!
dailyekhatch
Aug 15, 2011 06:45 AM
XxJDMugenCivicxX
Feb 5, 2007 03:21 PM
powwie
Apr 20, 2006 08:58 PM
Boring
17
May 9, 2005 09:09 AM
R-1303
Nov 26, 2002 01:41 AM
