Wut suspension are you running to put down 350whp or more?
Old Jul 28, 2005 | 10:40 AM
AzN_Flava's Avatar
Default Wut suspension are you running to put down 350whp or more?
I'm curious as into wut kind of suspesnion everyone is running in here? Reason I'm asking in here, is because it is more related to the guys with a turbo (but move if neccessary)...
Wut is everyone running? What does everyone think is the bare minimum to have as shocks/springs to put this power down? IE. Like is Koni yellows + H&R race springs good enough to put down this kind of power?
Old Jul 28, 2005 | 11:12 AM
b16sedan's Avatar
Default Re: Wut suspension are you running to put down 350whp or more? (AzN_Flava)
Skunk2 coil overs
Full-Race traction bars (gen1)
225/50/15 BFG's
A light foot
400+ WHP
Old Jul 28, 2005 | 11:23 AM
tthame1's Avatar
Default Re: Wut suspension are you running to put down 350whp or more? (b16sedan)
I'm running Skunk2 Pro-Series Coilovers. I love them. Removed front sway bar and Progress rear sway bar.
Modified by tthame1 at 3:24 PM 7/28/2005
Old Jul 28, 2005 | 11:56 AM
Dunc's Avatar
BCICAN
Default Re: Wut suspension are you running to put down 350whp or more? (tthame1)
Tein SS w/Comptech rear sway bar and tie bar.
Old Jul 28, 2005 | 12:59 PM
Quad-Damag's Avatar
Default Re: Wut suspension are you running to put down 350whp or more? (Dunc)
omni power 102whp
Old Jul 30, 2005 | 12:04 PM
AzN_Flava's Avatar
Default Re: Wut suspension are you running to put down 350whp or more? (Quad-Damage)
TTT for more responses....
Old Jul 30, 2005 | 12:30 PM
Rod.'s Avatar
cheap coilover
kyb adjustable shocks
dc rear tie bar
Old Jul 30, 2005 | 03:02 PM
s2kdre's Avatar
Default Re: Wut suspension are you running to put down 350whp or more? (Rod.)
koni yellows and groundcontrols
Old Jul 30, 2005 | 03:14 PM
EARLdaSQUIRREL's Avatar
official honda whore
Default Re: Wut suspension are you running to put down 350whp or more? (jdmhonda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmhonda &raquo;</TD></TR><TR><TD CLASS="quote">koni yellows and groundcontrols</TD></TR></TABLE>
same here
Old Jul 30, 2005 | 03:18 PM
2000BoostedEX's Avatar
Default Re: Wut suspension are you running to put down 350whp or more? (coptzer)
Tanabe Sustec Pro S-OC Coilovers
00 Ej8
Was 200hp about to be 300+
Old Jul 30, 2005 | 03:36 PM
White Smoke's Avatar
i my honda
Global Mod
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tthame1 &raquo;</TD></TR><TR><TD CLASS="quote">I'm running Skunk2 Pro-Series Coilovers. I love them. Removed front sway bar and Progress rear sway bar.
Curious, why did you lose the front sway?
And what kind of power are you making on the street?
I also run koni yellows and groundcontrols, along with a comptec rear sway/tie bar, FR traction bars and skunk2 camber kit.
But most important, QUAIF
Old Jul 31, 2005 | 06:34 PM
Makdaddynuge's Avatar
bump for an answer to that ^^
Old Jul 31, 2005 | 06:40 PM
lucidvtec's Avatar
a lsd will help alot...traction bars...drag springs...top of the list should be the LSD...i think
Old Jul 31, 2005 | 06:45 PM
Bailhatch's Avatar
Default Re: (Makdaddynuge)
a sway bar makes the suspension less independant. taking it off can aid in traction by letting the tires follow the ground, but that applies more to cornering than a flat dap strip. It will also reduce understeer in corners. If all is set up well the sway bars wont be doing much when you go straight so i guess its a good way to lose some weight on a drag car.
Old Jul 31, 2005 | 07:08 PM
red_crx's Avatar
Ground control coilovers and Tokico 5 ways
Old Jul 31, 2005 | 10:00 PM
rhettster's Avatar
Default Re: (Bailhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bailhatch &raquo;</TD></TR><TR><TD CLASS="quote">a sway bar makes the suspension less independant. taking it off can aid in traction by letting the tires follow the ground, but that applies more to cornering than a flat dap strip. It will also reduce understeer in corners. If all is set up well the sway bars wont be doing much when you go straight so i guess its a good way to lose some weight on a drag car.</TD></TR></TABLE>
No argument with regards to drag cars. But the thick Progress rear bar actually reduces understeer. You didn't say which sway bar you meant (front or rear), but I'd thought I'd clarify before this guy starts thinking that he'll improve his cornering characteristics by ditching the sway bars.
Old Aug 1, 2005 | 04:39 AM
tthame1's Avatar
Exactly . And to clarify, he means the front sway bar (or should mean). I've noticed that since removing it, the car corners much better and seems to get better all around traction. I upgraded the stock rear sway bar to the progress one (best one on the market imo) and it made a night and day difference. It completely changes the handling characteristics of the car. If you don't have one, I'd make that your next mod
For the guy that asked, my car is putting down 415whp.
Old Aug 1, 2005 | 08:34 AM
i my honda
Global Mod
Default Re: (tthame1)
For the guy that asked, my car is putting down 415whp.</TD></TR></TABLE>
So you are not getting more over steer with the front bar out and that stiff rear in?
I don't know about you guy's but I sure don't want anymore over-steer. My comptech rear sway/tie bar has already giving me more control over the rear (IE: over-steer). I was happy at that point but when I switched out the front Si sway and LCA's for the smaller EX bar and LCA's the over-steer is not to my liking.
So you are saying the over steer is not to overpowering for you? Sure if you are a track guy I can understand but if its a street car I would wanna keep that under-steer.
Old Aug 1, 2005 | 09:43 AM
tthame1's Avatar
Default Re: (White Smoke)
It's a street car. I LOVE the oversteer I get. To me, its much easier to handle oversteer than understeer. To correct oversteer, you just give the car a little more gas. Whereas with understeer, you are just screwed. I hate a car that pushes. FWD Drifts&gt;*
Old Aug 1, 2005 | 10:01 AM
T4eg's Avatar
BG **** coilovers up front and stock blown struts with 1000#'s in rear.
Old Aug 1, 2005 | 10:33 AM
Bailhatch's Avatar
Default Re: (T4eg)
ya sorry i was refering to having more roll stiffness in the rear (no front bar or bigger rear)
Digitalis
May 21, 2015 09:15 PM
CivicSiRacer
18
Aug 31, 2007 11:51 AM
boostincoupe
Suspension & Brakes
16
Jun 15, 2006 02:41 PM
lowrightor
30
Mar 30, 2004 03:24 AM
Rratedcivichatch
12
Aug 23, 2002 08:30 PM
